4 Replies Latest reply on Oct 15, 2012 12:04 PM by gsolorio
    How to - Varibale Data in a PDF for mass email?
    PlesePrintJ Level 1
      I have a question for the Adobe InDesign community...
      Is there an easy way to add variable data to an InDesign PDF document for mass emailing?
      I am sending out a newsletter to over 500 emails and I'd like to add the client name to the PDF document and have it send to the appropriate email without having to do each one individually. We have Design Merge, however the only way to save out the variable data for the newsletter is to save them as post-scripts and then convert each file into a PDF. However...once all 500 records are made, is there a way to have the appropriate variable documents go to the right emails?
      I'm thinking I either need to do each email one at a time (which is time consuming)...or just redesign the newsletter as an html email and use something like Mail Chimp to have it include client names in the email as "IFNames."
      Anyone have any suggestions?
      Thank you.
        • 1. Re: How to - Varibale Data in a PDF for mass email?
          Michael Gianino Level 4
          I don't understand what you want. Parts of what you want are possible, and it seems you understand how to do it (sort of).
          PlesePrintJ wrote:
          I am sending out a newsletter to over 500 emails and I'd like to add the client name to the PDF document…
          With the Mail Merge function within InDesign, you can take your (let's say four-page) newsletter and add 500 client names and email addresses, but it would result in a 2,000-page InDesign document (with 500 consecutive copies of your newsletter, each with a different name and email address, or what ever other data you need). That document can easily be exported to PDF, and the PDF can easily be broken into 500 four-page PDFs with Acrobat. If the page counts are an issue, you could break your data file into smaller chunks, and do several merges.
          PlesePrintJ wrote:
          …and have it send to the appropriate email without having to do each one individually.
          Here's where I don't understand you. Are you looking to make one email with 500 recipients, and have the appropriate PDF be attached automatically, without you having to choose the appropriate PDF with the cooresponding email? If so, that sounds like an email issue, more than an InDesign one. It may be (and probably is) something that can be automated, but I don't think InDesign is the step that is getting in your way.
          I don't know anything about Design Merge, but Data Merge doesn't require this step. You can export to PDF directly from the InDesign document that is created by the Data Merge process.
          • 2. Re: How to - Varibale Data in a PDF for mass email?
            nicolaslevet
            In my opinion, it's not possible with indesign, the best you will obtain is 500 times the same PDF file with your variable, that you will have to reconnect to your e-mails separately, and considering that the name of each PDF file won't have the name of the variable in it, all of this will result a real pain.
            There is maybe an alternative using MS Word mail merge (please don't make this face of disgust ;-) ) because MS Word has a data merge system that can use the e-mail address field imported in your word files to automatically send each records directely using the e.mail address as a "to:" field in your e-mail browser (i.e Outlook, Firebird, Mail (for Mac)... well any MAPI compatiple software).
            The problem is that you will have to redo you newsletter in MS Word, hmm, that's sounds nefarious, but I don't see any solution, unless you find an Indesign plug-in that is capable of handeling this kind of issue. I made a quick search on the net but found nothing, when I say quick I mean it ;-).
            Regards
            • 3. Re: How to - Varibale Data in a PDF for mass email?
              PlesePrintJ Level 1
              I've found solution via Adobe Acrobat X Pro and a 3rd party plugin called AutoMailMerge by EverMap.
              Thank you to everyone who responded in helping me.
              • 4. Re: How to - Varibale Data in a PDF for mass email?
                gsolorio
                Have any of you tried AutoMailMerge by EverMap with a PDF for 1,000+ different emails and mailing them (or emailing) and did it work without any issues?  I'm afraid that what if someone else's record goes to the wrong form.  I'm thinking of using this tool and sending this to 12,000+ people.
