2 Replies Latest reply on Jun 3, 2008 12:34 AM by StrangeHeart
    font coding problem
    StrangeHeart
      Hi
      I am hving pb in coding
      1- I need the font to be align to center.
      2- I need how to code the font family e.g "Arial" etc...
      // here i hve given the family font but it does not work
      myFormat.size = 25;
      myFormat.font = ("fontfamily", "Arial");
      //end
      i have put the coding below, pls do chck in help me in it.
      Thnks
        • 1. Re: font coding problem
          clbeech Level 3
          when using a TextFormat Object, you should write:
          myFormat.size = 25;
          myFormat.font = 'Arial';
          myFormat.align = 'center';
          and when setting the format to the textField you do not need to call _root since the TextFormat Object is within this scope.
          I also see that you have not 'declared' the TextFormat Object here previous to setting the properties, as in:
          var myFormat = new TextFormat();
          you can also set the color property within the format Object, however in either method (eg. the textField.color property) you need to use a hexadecimal number, as in:
          myFormat.color = 0xFF0000; //color is red
          • 2. Re: font coding problem
            StrangeHeart Level 1
            Hi
            Thanks it is working now fine
            I appricatie ur help.
            Bye
            quote:
            myFormat.size = 25;
