5 Replies Latest reply on Nov 3, 2011 9:31 AM by Jim_Simon
    NLE Workstations - POST YOURS FOR FEEDBACK!
    dreinz Level 1
      55299  ASUS Sabertooth X58 LGA1366 DDR3 CrossFireX SLI 3PCI-E16 2PCI-E1 PCI USB 3.0 Motherboard  [SABERTOOTH X58[Reg. $216.41] 1 $209.99 $209.99
      62522  Intel Core i7 980 6 Core Processor LGA1366 3.33GHZ Westmere 12MB L3 Cache 130W 32NM Retail Box  [BX80613I7980[Reg. $674.04] 1 $639.99 $639.99
      60445
      Crucial M4 SSD Micron C400 128GB 2.5IN Solid State Disk Flash Drive SATA3 6Gbps  [CT128M4SSD2[Reg. $232.53]
      56629
      PNY GeForce GTX 580 Fermi 772MHZ 1536MB 4GHZ GDDR5 2xDVI Mini-HDMI PCI-E DirectX 11 Video Card  [VCGGTX580XPB[Reg. $539.99] 1 $499.99 $499.99
      56934
      Western Digital RE4 1TB SATA3 7200RPM 64MB Cache 3.5IN Hard Drive OEM  [WD1003FBYX
      62827
      Corsair Enthusiast Series TX850M 850W ATX Modular Power Supply Active PFC 120MM Fan 5 Year Warranty  [CP-9020004-NA[Reg. $140.76] 1 $119.99 $119.99
      62879
      LG BH12LS38 12X Blu Ray Rewriter SATA Black Lightscribe 3D Playback  [BH12LS38[Reg. $115.21]
      41137
      Lian Li PC-A70F Black Aluminum E-ATX Full Tower Case 5X5.25 1X3.5 10X3.5INT No PS USB Audio 1394  [PC-A70F[Reg. $187.15] 1 $164.99 $164.99
      57080
      Corsair Vengeance 12GB 3X4GB DDR3-1600 CL9-9-9-24 XMP Triple Channel Core i7 Memory  [CMZ12GX3M3A1600C9[Reg. $90.25] 2 $74.99 $149.98
      54360
      LSI MegaRAID 9240-4I 4 Port 6Gbps PCIEx8 Low Profile SAS/SATA/RAID Controller Card with Cables  [LSI00203[Reg. $254.22] 1 $232.50 $232.50
      1 Crucial SSD for you boot drive and applications, 1 Crucial SSD for a scratch disk, and 4 1TB Western Digital RE4 drives for storage
      RE4s in a RAID 5 array using the LSI card
      Community thoughts on this set-up?
        • 1. Re: NLE Workstations - POST YOURS FOR FEEDBACK!
          Jim_Simon Level 9
          All in all looks nice.
          But you forgot a Project disk (which should be separate from the Media drive).
          • 2. Re: NLE Workstations - POST YOURS FOR FEEDBACK!
            Martin Douglas Level 2
            Should it?
            Can't say I've noticed a difference
            Martin
            • 3. Re: NLE Workstations - POST YOURS FOR FEEDBACK!
              JEShort01 Level 4
              Dreinz,
              You've got some excellent choices in your build so far, but some choices that you should change / strongly reconsider:
              1) Keep the book M4, but DEFINITELY change out your 2nd SSD to something rotating at 7200; I would suggest dumping your "scratch" M4 budet to fund 2x1TB in RAID 0 (off motherboard controller) for Media cache, Media cache DB, and render outputs. You can point Windows "scratch" to any of your 3 drive arrays (boot, RAID 0 or 4x1TB RAID) and with 24GB of RAM it will work just fine (my system is somewhat similar to what you are planning).
              2) Newegg reviews, which I trust quite a bit, completely slam your RAID card choice; That being said, if you are sure the Asus + 6-core Intel will work fine with it OK. Personally, I don't like wasting my time with any computer component that doesn't get 4+ Eggs for a video edit build
              3) Not essential, but I would strongly suggest the extra cash to upgrade to Corsair's AX850 P/S; it is an excellent design (newer, completely modular cabling, better performance, etc.)
              Good luck!
              Jim
              • 4. Re: NLE Workstations - POST YOURS FOR FEEDBACK!
                ECBowen Most Valuable Participant
                You might want to wait a little longer before you decide on a configuration.
                Eric
                ADK
                • 5. Re: NLE Workstations - POST YOURS FOR FEEDBACK!
                  Jim_Simon Level 9
                  Occasionally I'm forced to work with less than optimal drive configuration.  I definitely notice a difference when the Media is on a separate drive from other assets like audio and still images (which go on the Project drive).
                  Of course, that is using single drives.  I suppose it might not show as much difference when using a faster RAID array.
