1 Reply Latest reply on Nov 3, 2011 11:10 PM by Lewiz
    Guarantueed Premiere CS5 crash when applying EQ and Multiband Compressor together on mono track
    Lewiz Level 1
      Hi there everyone,
      I started a discussion a few days ago on an AppCrash subject, resulting in the discovery of a consequent failure which I have been able to reproduce ever since. I would now like to see if any other Premiere users can confirm this failure, to find out whether it's a common issue or just my configuration needing some tweaking.
      If you are a Premiere CS5 user, working with a Matrox MX02 LE system, I would like to invite you to do the following test:
      - Create a new project: MPE with GPU enabled, HDV capture format
      - Create a new sequence: 1080i @ 25 fps, Matrox MPEG-2 I-frame HD codec, one mono audio track and one video track
      - Capture some footage
      - Map the audio of the captured tracks to mono
      - Toss a few shots on the timeline with audio
      - Now apply a mono EQ effect to all audioclips in the timeline
      - Then apply the (mono) Multiband Compressor effect to all audioclips in the timeline, on top of the EQ effect
      - Press spacebar to play the timeline, do a match frame edit to switch to your source monitor and press spacebar to play that one, then switch back to your program monitor and press spacebar again
      If a Windows dialog box pops up saying "Premiere has stopped working" or anything the like, please let me know. If Premiere still functions, please let me know as well. I have a very "standard" workstation that was tested thoroughly by the professionals who built it, no crappy drivers or bad hardware, so I guess more people should be encountering this problem.
      Any cooperation with this issue is very much appreciated!
