0 Replies Latest reply on Nov 4, 2011 12:04 AM by ShunShunLikLik
    Distortion in Audio Recording
    ShunShunLikLik
      Hi
      I have written a audio recorder. It works fine in my XP computer. However, when I test it on Vista, serious distortion found. Only half of the sentance is recorded and the rate of audio is different.
      Here is an extract of my source code:
         protected function recBtn_clickHandler(event:MouseEvent):void{
          if (event.currentTarget.selected == true){
           event.currentTarget.label = "Stop";
           rec=new ByteArray();
           mic = Microphone.getMicrophone();
           mic.setUseEchoSuppression(true);
           mic.setSilenceLevel(10,5);
           mic.rate=44;
           mic.addEventListener(SampleDataEvent.SAMPLE_DATA, getMicAudio);
           ply_Btn.enabled=false;
           ps_Btn.enabled=false;
          else{
           mic.removeEventListener(SampleDataEvent.SAMPLE_DATA, getMicAudio);
           event.currentTarget.label = "Record";
           ply_Btn.enabled=true;
           ps_Btn.enabled=true;
         private function playRecorded(e:SampleDataEvent): void{
          //what must be done, for playing at same rate.
          if (!rec.bytesAvailable > 0) return;
          for (var i:int = 0; i < 8192; i++){
           var sample:Number = 0;
           if (rec.bytesAvailable > 0) sample = rec.readFloat();
           e.data.writeFloat(sample);
      I have tried to set different rate values but the results are even worse.
      The only difference that I found is the audio device, which is SoundMax Digital Audio in XP and SoundMax Integrated Digital HD Audio in Vista. Do you think this is a cause of the problem?
