1. Re: Looking to adjust page and lettering size into mm
Monika Gause Nov 3, 2011 5:16 AM (in response to simpson246)For the page size: which version?
for the font size: As you need to convert the type to outlines for vinyl cutting anyway, just do it now and then use the transform panel (for instance) to adjust the size.
2. Re: Looking to adjust page and lettering size into mm
Steve Fairbairn Nov 3, 2011 5:17 AM (in response to simpson246)As far as I know the only way you can see the measurements of each individual letter is to outline the type (Cmd+Shift+O on a Mac).
To adjust the artboard size go to File > Document Setup
To adjust the size of the lettering, use the Transform palette. Click on the link mark on the right to constrain proportions.
Go to Preferences > Units & Display Performance to change units to millimetres.
3. Re: Looking to adjust page and lettering size into mm
simpson246 Nov 3, 2011 6:05 AM (in response to simpson246)Thanks for the reply.
The version is CS5 on windows 7.
font is outlined yeah, wheres the transofmr panel please?
Thanks both of you
4. Re: Looking to adjust page and lettering size into mm
Grant H Nov 3, 2011 6:46 AM (in response to simpson246)Press E for free transform or select object r/click transform>scale or select object and enter new dimensions in transform panel or in the top control bar
G
oh:
press shift F8, or window>transform
5. Re: Looking to adjust page and lettering size into mm
tonyharmer Nov 3, 2011 6:50 AM (in response to simpson246)Actually, you can do both of those things quite simply.
Firstly, your page size can be set in the Document Setup option from the file menu, and simply type the numbers and the measurement units in the field: 1800mm
If you want to set all of your documents to use mm natively, simply have InDesign launched with no open documents, and go to the preferences. From there, choose Units.
For the type, simply add mm after the numbers in the size field. InDesign will automatically convert them to points. You can convert to outlines when you're ready to send the file.
6. Re: Looking to adjust page and lettering size into mm
Monika Gause Nov 3, 2011 6:52 AM (in response to simpson246)simpson246 wrote:
you should also consider the manual for help on this kind of questions.
7. Re: Looking to adjust page and lettering size into mm
simpson246 Nov 3, 2011 6:52 AM (in response to simpson246)Thanks for the replies,
I've got the transform window although it t=states 'pt'.
Whats this please as I would like it in MM.
I would also like to only enter the length and for the width to be done automartically.
8. Re: Looking to adjust page and lettering size into mm
Grant H Nov 3, 2011 6:55 AM (in response to simpson246)I've got the transform window although it t=states 'pt'.
oh dear.... pt is points
change your units from points to mm,
G -
9. Re: Looking to adjust page and lettering size into mm
simpson246 Nov 3, 2011 7:06 AM (in response to Grant H)Thank you all, Sorted
