1. Re: Flash Builder 4.5 installer "unable to locate its companion shared library"
jnojr Nov 3, 2011 12:17 PM (in response to jnojr)I rolled this again, this time leaving AIR in and not adding the update. I get the same message, three times.
2. Re: Flash Builder 4.5 installer "unable to locate its companion shared library"
ninetang Jul 24, 2012 1:57 AM (in response to jnojr)I encountered the same prompt too, so how did you solve it, Mr jnojr ?
3. Re: Flash Builder 4.5 installer "unable to locate its companion shared library"
visioned Aug 5, 2012 3:17 AM (in response to jnojr)I encountered also a problem with starting up Flash builder premium 4.6.
Adobe Flash builder unfortunately searces for a eclipse plugin in the following directory.
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\eclipse\plugins\com.adobe.flexbuilder.ui_4.6.1.335153/welcom/index.html?firstLaunch=f alse&edition=prem&version=460…
I guess the program can't find the startup page, but it already is loaded. Could it be that the program is looking for a deleted file, which I did.
Look forward to hear some solution.
Regards,
Ed Boon
visioned.nl
4. Re: Flash Builder 4.5 installer "unable to locate its companion shared library"
sabird Aug 20, 2012 7:11 AM (in response to visioned)I'm experiencing the same problem as visioned, but I'm on a Mac. I believe this is the first time I've attempted to open Flash Builder 4.6 since I upgraded my laptop a couple of weeks ago. Do I have to reinstall Flash Builder, or is there some file I can replace or link I can fix?
