6 Replies Latest reply on Nov 3, 2011 2:19 PM by JLAFARGUE
    Adobe LiveCycle loses its mind when generating the XML source
    JLAFARGUE
      Could somebody tell me what is causing Adobe LiveCyle to lose its mind and generate hundreds of lines that are merely repeats of this:
      <?templateDesigner StyleID aped0?>
      Here's an example of what it looks like for one field on a form.  The tag is border
      <border presence="hidden">
      The line is repeated 250 times !!
      Is this a LiveCycle bug or did I do something screwy to cause this?
      Could I just delete the duplicate lines from the XML?
      <field minH="8.2042mm" minW="33.02mm" name="CPN" x="99.1101mm" y="8.2042mm">
      <ui>
      <textEdit>
      <?templateDesigner StyleID aped0?></border>
      <margin/>
      </textEdit>
      </ui>
      <font typeface="Arial" weight="bold"/>
      <margin bottomInset="0.254mm" leftInset="1mm" rightInset="1mm" topInset="1mm"/>
      <para vAlign="middle"/>
      <caption placement="top" reserve="2.54mm">
      <font baselineShift="0pt" size="5.8pt" typeface="Arial"/>
      <para marginLeft="0pt" marginRight="0pt" spaceAbove="0pt" spaceBelow="0pt" textIndent="0pt" vAlign="middle"/>
      <value>
      <text>4. COMPLAINT NO</text>
      </value>
      </caption>
      <border>
      <edge presence="hidden"/>
      <corner presence="hidden"/>
      <edge/>
      <edge/>
      <corner/>
      <corner/>
      </border>
      <event activity="enter">
      <script contentType="application/x-javascript">if (testscripts.enterFld(this)) {
      var back="parent.Ten98";
      var next="parent.IncidentNature";
      jscripts.setTab(this,next,back);
      jscripts.boxEdges(this);
      }</script>
      </event>
      <event activity="exit">
      <script contentType="application/x-javascript">if (testscripts.exitFld(this)) {
      this.rawValue = IncidentNumber.formatIncNum(this.rawValue);
      MNPD.Form130.MNPDTrackingNumber.rawValue = TrackingNumber.createTrackingNumber("AFR-FORM130",
      MNPD.ND_Host.rawValue,
      MNPD.ND_atsEmployeeNumber.rawValue,
      this.rawValue);
      console.println(MNPD.Form130.MNPDTrackingNumber.rawValue);
      xfa.resolveNode("MNPD.#pageSet[0].PageArea1.CPN").rawValue = this.rawValue;
      var r = testscripts.validateFld(this);
      jscripts.unboxEdges(this);
      testscripts.stepFld(this,r);
      }</script>
      </event>
      <event activity="change">
      <script contentType="application/x-javascript">xfa.resolveNode("MNPD.#pageSet[0].PageArea1.CPN"). rawValue = this.rawValue;</script>
      </event>
      <bind match="none"/>
      </field>
