1 Reply Latest reply on Nov 4, 2011 4:26 AM by Harm Millaard
    Cannot Export MPEG2 with Audio
    glaustin Level 1
      Hi Guys
      I have a bizare problem. I've been trying to export a short 2 min movie to MPEG 2 for YouTube but it won't export the audio with video and exports the audio as a separate file (yes, the export audio box is checked)! Yet it will export with audio to AVI. What could I have switched off or need to switch on?
      Can anyone advise please? The movie was captured using the DV PAL Codec (720x576). The export settings are:
      Audio Format MPEG
      Basic Audio
      Codec: mainConcept MPEG Audio
      Audio layer: Mpeg1 Layer II Audio
      Audio mode :Stereo
      Sample size: 16bit
      Frequency: 48Khz
      Bit rate: 224
      Psyc mode: Model 2
      Demphasis: No emphasis
      Enable CRC - Set Original bit: all off
      Video Format  MPEG2
      Pre-set PAL DV High Quality
      Basic Video Settings
      Codec: MainConcept MPEG Vide
      TV Standard: PAL (I'm in Europe)
      Frame: 720x576
      Frame rate: 25
      Field order: Lower
      Pixel Aspect: Standard
      Profile: Main
      Level: Main
      Render at max: off
      Bit rate: VBR 2 pass
      min bit rate: 2.4
      Target bit rate 4.2
      max bit rate: 6
      GOP Settings
      M & N frames: 3
      Closed GOP: 0
      Macroblock: 10
      VBV buffer: 112
      Noise: sensitivity
      Write SDE: No
      Force VBV oxfff
      Intra DC 9bits
      Write sequence end code: Yes
      Embed SVCD: No
      Ignore frame interval: 0
