4 Replies Latest reply on Nov 4, 2011 7:21 AM by sotospeak (carlo bazzo)
    changed in CS5.5 ?
      I have a grid of textframes in a spread for testing.
      I need to know which tf is on the right side and which on the left side of the spread.
      I thought to compare the tf parent arguing that the page should be different. I used the getPage function by Marc Autret: well in ID CS4 everything is working as I expected. If I select a tf on the left side I get "Page:6" and if I select one tf on the right I get "Page:7".
      But in ID CS5.5, any tf I select I get "The textframe is placed on a spread!".
      Maybe someone can explain what is changed in ID 5.5 with this respect? Thank you.
      Here is the code:
      TextFrame.prototype.getPage = function()
      // Returns the containing Page of this TextFrame
      var p = this.parent,
           pc;
      while( pc=p.constructor )
           if( pc == Page )
                return p;
           if( pc == Spread || pc == MasterSpread )
                throw Error("The textframe is placed on a spread!");
           if( 'parentTextFrames' in p && !(p=p.parentTextFrames[0]) )
                throw Error("The textframe's container overflows!");
           p=p.parent;
      // Sample code (assuming a text frame is selected)
      var tf = app.selection[0],
           pg;
      try {
           pg = tf.getPage();
           alert(tf.parent.parent);
           alert( "Page: " + pg.name + " Side: " + pg.side);
      catch(e)
           alert( e );
