1 Reply Latest reply on Nov 4, 2011 4:36 AM by Claudiu Ursica
    problem --> when connect to webservice via flex 4.5 getting objectProxt instead of complex object
    ophirroit
      when I connect to web service via flex 4.5 , and try to get result of type WSDataTable created in java:
      public class WSDataTable {
      private Object[][] myData =null;
      private String[] collumns=null;
      private int size = 0;
      private long totalResultSize=-1;
      private int resultsPerPage = 0;
      private int currentPage = 1;
      private Object[] newData = null;
      When the server is send  me complex object with type NewObject as objects  in the myData array  , when i try to reach in flex WSDataTable.myData[0][0]  I'm getting type objectProxy instaed of NewObject.
      I try to change the parameter   makeObjectsBindable to false in the operation then I'm getting object instaed of object proxy but whedn I try to cast this object to NewObject I'm getting class clast exception.\
      what should I do ?
