4 Replies Latest reply on Nov 7, 2011 2:58 AM by seba1395
    How change size of an anchored object ?
    seba1395
      Hello, I make a script that change size of a element by looking name (label and name).
      So It's work very well :
      var myStories = app.activeDocument.pageItems.everyItem().getElements();
      for(var i=0;i<myStories.length;i++){
      if(myStories[i].name=="Post_it"){
      var g_obj1 = get1(myStories[i]);
      var g_obj2 = get2(myStories[i]);
      var g_obj3 = get3(myStories[i]);
      var g_obj4 = get4(myStories[i]) + 5 ;
      myStories[i].geometricBounds = [g_obj1,g_obj2,g_obj3,g_obj4];
      But when I copy it and paste in a text to do a anchored object, it doesn't work!
      I check the name and the label, it's the same.
      Why it doesn't work when the object in anchored and how can I resolved it ?
      Thanks a lot!
        • 1. Re: How change size of an anchored object ?
          கற்பனை (Imagine) Level 3
          Because the anchored objects are nested to the parent objects.  you must have the second iteration for getting those objects.
          • 2. Re: How change size of an anchored object ?
            seba1395 Level 1
            Thank for your answer !
            How can I do that? Do you have an example ?
            • 3. Re: How change size of an anchored object ?
              csm_phil Level 4
              Hi Seba,
              Can you please try the below JS code, this code will check the anchored items whose label name is "Post_it" corect it will change the anchored frame size is 5 pica.
              I hope you expect this. Otherwise please revert if you have update any.
              myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.picas;
              myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.picas;
              var myPg = myDoc.allPageItems;
              for (i=0; i<myPg.length; i++){
                  var myFrame = myPg[i];
                  if(myFrame instanceof TextFrame){
                      //alert(myFrame.label);
                      if(myFrame.label==" Post_it"){
                          if(myFrame.parent.constructor.name=="Character"){
                              tf = myFrame.parent.textFrames[0].geometricBounds;
                              tf[2] = tf[0] + 5;
                              myFrame.parent.textFrames[0].geometricBounds = tf;
              thx
              csm_phil
              • 4. Re: How change size of an anchored object ?
                seba1395 Level 1
                Yes! Very nice ! Thank a lot !
                Like this :
                var myStories = app.activeDocument.allPageItems;
                        if(myStories[i]  instanceof TextFrame){
                                if(myStories[i].name=="Post_it" || myStories[i].label=="Post_it"){
                                        var num_page_active = myStories[i].parentPage.name;
                                        alert(num_page_active);
                So, It's work! Now, I would like to do this only on the even page.
                In CS5, all is ok :
                                         Number.prototype.isEven = function (){return (this%2 == 0) ? true : false;}
                                        if(Number(num_page_active).isEven()==false){
                                            myStories[i].name="Post_it_Dec";
                                            myStories[i].label="Post_it_Dec";
                But in CS4, the parent.name give me some problème that I can't resolved.
                In CS4, it does'nt know ".name" but ".label" only.
                So this does'nt work for CS4 :
                                              if( myStories[i].label=="Post_it"){
                                                        myStories[i].select();
                                                        var num_page_active = myStories[i].parent.name;
        myStories[i].label ="Post_it_Dec";
                Can you help me here or I create a new topic?
