4 Replies Latest reply on Nov 7, 2011 3:17 PM by bogiesan
    3D Path Layer Question - Pls Help
    kevinokev
      To get you up to speed, I have a large composition with all elements set up as 3D layers.  These layers are all in different positions/depths within the comp.
      I have a complicated camera animation in place to move about the individual objects.  What I'm trying to do is create a path that will in-turn be a 3D layer and would like to be able to select individual points of that path and adjust the z depth accordingly.
      I need it to snake it's way in and out of this pre-existing 3D comp.
      The idea is to use Trapcode's 3D stroke to animate the line moving along, however once I make the path into a 3D object, I can't seem to edit the individual points depth.
      Is this even possible?  Is there another method with AfterEffects I can try.
      Like I said, I've already got the elments and camera move plotted, I need to plot a path in space around these elements.
      ANY input is greatly appreciated as I've been at this all day and I initially thought it would be something simple.
      Thanks to all.
