6 Replies Latest reply on Nov 6, 2011 1:29 AM by yajiv_viki
    Its possible to convert Apple script to Java script
    yajiv_viki Level 2
      Please Help me anyone to do that script.
      its possible to convert below mentioned Apple script to Java Script.
      Thanks in advance.
      Help me......!
      -yajiv
      Code:
      tell me to addImageLabels()
      on addImageLabels()
                tell application "Adobe InDesign CS5"
                          set numberAdded to 0
                  activate
                          set enable redraw of script preferences to true
                          set currentFonts to (get name of every font)
                          if currentFonts does not contain fontname then
                                    display dialog "The font \"" & fontname & "\" is not active on your system." buttons {"Continue anyway", "Cancel"} default button 2
                          end if
                          tell document 1
        -- get a list of unique page IDs in this document
                                    set allpageids to my getPageIds()
                                    repeat with p from 1 to (length of allpageids)
                                              set pgid to item p of allpageids
        -- loop through these, getting a list of unique page item IDs to inspect
                                              tell page id pgid
                                                        set pageitems to (get id of every page item)
                                                        repeat with i from 1 to (length of pageitems)
        set pid to item i of pageitems
        tell page item id pid
        try
        -- certain boxes will fail to yield a content type, whatever
        if content type is graphic type then
        set c to class
        set i to id
        -- get the name of the link, i.e. the filename, subject to labelFormat (full name, first six chars, etc.)
        set gn to my getImageName(pgid, c, i)
        if (gn is not "Empty") and (gn is not "") then
        set b to visible bounds
        set h to (item 3 of b) - (item 1 of b)
        set newtop to (item 1 of b) + (h / 2)
        set item 1 of b to newtop
        set w to (item 4 of b) - (item 2 of b)
        if w < minwidth then
        set item 4 of b to ((item 4 of b) + 0.2)
        set item 2 of b to ((item 2 of b) - 0.2)
        end if
        set l to (make new text frame at beginning of page id pgid with properties {visible bounds:b, fill color:fillcolor, contents:gn, label:"imagelabel"})
        tell l
        tell paragraph 1
        set justification to center align
        try
        set applied font to fontname
        end try
        set point size to fontsize
        set fill color to textcolor
        end tell
        set inset spacing of text frame preferences to ((insetspacing as string) & " in") as string
        fit given frame to content
        set numberAdded to numberAdded + 1
        end tell
        end if
        end if
        end try
        end tell
                                                        end repeat
                                              end tell
                                    end repeat -- allpageids
                          end tell -- document 1
        display dialog "Added " & numberAdded & " labels." buttons {okButton} default button 1 giving up after 10 with title scriptName
                end tell -- InDesign
      end addImageLabels
      on getPageIds()
                          tell document 1
                                    tell master spread 1
                                              set masterpageids to (get id of every page)
                                    end tell
                                    set docpageids to (get id of every page)
                          end tell
                end tell
                return masterpageids & docpageids
      end getPageIds
      on getImageName(int1, cla1, int2)
                          tell document 1
                                    tell page id int1
                                              if cla1 is rectangle then
                                                        set imagename to (name of item link of graphic 1 of rectangle id int2)
                                              else if cla1 is polygon then
                                                        set imagename to (name of item link of graphic 1 of polygon id int2)
                                              else
                                                        return "Unknown"
                                              end if
                                              try
                                                        if (labelformat is "First six characters") then
        return (characters 1 thru 6 of imagename) as string
                                                        else if (labelformat is "Base name of linked file") then
        set op to offset of "." in imagename
        return (characters 1 thru (op - 1)) of imagename as string
                                                        else
        return imagename
                                                        end if
                                              on error
                                                        return "Empty"
                                              end try
                                    end tell
                          end tell
                end tell
      end getImageName
