This content has been marked as final.
Show 6 replies
1. Re: Vertical Page movement
Newsgroup_User Jun 5, 2008 3:59 AM (in response to gwiebe)You have applied behaviors to your Library item (Header.lbi). That's not
only not allowed, but it also creates a mess on your page. Please remove
the unneccessary, redundant, and illegal javascript *and* <body> tag from
the Library item. In the future, only create your Library items AFTER all
interactivity has been added, not before.
In addition, and actually much worse, you have TWO instances of the !--
#BeginLibraryItem "/Library/Header.lbi" --> markup, and only ONE
correspnding instance of <!-- #EndLibraryItem --> markup. You must fix this
or DW is going to act very strange.
Now, to your problem. You are linking to new pages on each thumb. In other
words, when you click on thumb2, it links you to page2, and when you click
on thumb3, it links to page3. This is an awkward way to do that, since you
have to create and maintain each of those pages. A much better way to do
that would be to let the thumb click just swap an image in the center of the
page, thereby allowing you to stay on a single page. However, since each of
those images is ~128K, your page would be massively heavy. The solution is
to not use the image swap, but to use the Set Text behavior. Each thumb
click would then dynamically write the markup for a particular image into
the same container in the center of the page (table cell), allowing you all
the benefits of staying on a single page, but not encumbering the page with
the aggregate weight of the central, enlarged images, since each image is
only fetched when it is requested, not when the page initially loads. To
see an example of this, go here -
http://dreamweaverresources.com/tutorials/settextoflayer.htm
and a tutorial
http://www.dreamweaverresources.com/tutorials/settextoflayer.htm
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"gweeb" <webforumsuser@macromedia.com> wrote in message
news:g27mq9$1nq$1@forums.macromedia.com...
> Hello
> I was wondering how to keep a page from moving to the top when you click
> on a
> link to go to another page. I am trying to set up a pic gallery. When I
> click
> on a thumbnail it goes to another page that shows that image bigger, but I
> want
> the page to stay in the same vertical location rather than scooting the
> top of
> the new page. What or can I do to keep the page in the same spot?
> Thanks
> Gerry
> http://www.prominenthomesont.com/pages/customhomes/alpha.html
> Using dreamweaver CS3 Mac
2. Re: Vertical Page movement
Newsgroup_User Jun 5, 2008 7:24 AM (in response to gwiebe)Those 2 links point to the same page.
Walt
"Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
news:g28gu1$sn6$1@forums.macromedia.com...
> this or DW is going to act very strange.
> other words, when you click on thumb2, it links you to page2, and when you
> click on thumb3, it links to page3. This is an awkward way to do that,
> since you have to create and maintain each of those pages. A much better
> way to do that would be to let the thumb click just swap an image in the
> center of the page, thereby allowing you to stay on a single page.
> However, since each of those images is ~128K, your page would be massively
> heavy. The solution is to not use the image swap, but to use the Set Text
> behavior. Each thumb click would then dynamically write the markup for a
> particular image into the same container in the center of the page (table
> cell), allowing you all the benefits of staying on a single page, but not
> encumbering the page with the aggregate weight of the central, enlarged
> images, since each image is only fetched when it is requested, not when
> the page initially loads. To see an example of this, go here -
> and a tutorial
>> Hello
>> on a
>> click
>> I want
>> top of
>> Thanks
>> Gerry
3. Re: Vertical Page movement
Newsgroup_User Jun 5, 2008 8:59 AM (in response to gwiebe)LOL - so they do!
Heh - I was just checking to see if you were paying attention. Your gold
star is in the mail....
"Walt F. Schaefer" <walt@waltswebworx.com> wrote in message
news:g28svj$c0i$1@forums.macromedia.com...
> Walt
>> all interactivity has been added, not before.
>> you click on thumb3, it links to page3. This is an awkward way to do
>> that, since you have to create and maintain each of those pages. A much
>> better way to do that would be to let the thumb click just swap an image
>> in the center of the page, thereby allowing you to stay on a single page.
>> massively heavy. The solution is to not use the image swap, but to use
>> the Set Text behavior. Each thumb click would then dynamically write the
>> markup for a particular image into the same container in the center of
>> the page (table cell), allowing you all the benefits of staying on a
>> single page, but not encumbering the page with the aggregate weight of
>> the central, enlarged images, since each image is only fetched when it is
>> requested, not when the page initially loads. To see an example of this,
>> go here -
>> and a tutorial
>>> Hello
>>> on a
>>> I click
>>> I want
>>> top of
>>> Thanks
>>> Gerry
4. Re: Vertical Page movement
gwiebe Jun 5, 2008 1:45 PM (in response to Newsgroup_User)Thanks Ace for your help. I appreciate it
I am not sure what you mean by this part
"You have applied behaviors to your Library item (Header.lbi). That's not
interactivity has been added, not before."
Does this mean I cannot have java script in a library item? Or is it my lack of knowlege with proper coding?
Cheers
G.
5. Re: Vertical Page movement
Newsgroup_User Jun 5, 2008 2:15 PM (in response to Newsgroup_User)> Does this mean I cannot have java script in a library item?
You can have javascript anywhere, but it *does* mean that once you make a
Library item, you CANNOT apply a behavior to it. Why? Think about it:
1. A Library item can only be inserted into the page between <body> and
<body>
2. Thus, a Library item cannot, itself, contain <body> tags, otherwise the
insertion of it into a page would result in duplicate body tags
3. Many behaviors need to also insert some javascript call into the body
tag
4. If you apply a behavior to a Library item, which cannot have a body tag,
where is that javascript call to be placed?
That's what I mean.
Yes, that too, but everybody gotta be somewhere!
news:g29j95$6u8$1@forums.macromedia.com...
> lack
> Cheers
> G.
6. Re: Vertical Page movement
Guest Jun 20, 2008 12:54 PM (in response to gwiebe)
realy it created a mess on my page thank you very much
