3 Replies Latest reply on Nov 7, 2011 10:16 PM by Flex harUI
    Flex e4x XML can't figure out?
    Log Home Level 1
      I'm trying to figure out e4x and flex.  Normally I use Connect to Data / Serices, but in this particular case, the XML is set up more nested.  I'm trying to build a road conditions app for Colorado, here is the XML URL:
      http://www.cotrip.org/xml/cameras.xml
      Why am I not able to see the 'ImageLocation' in my List?  When I put a breakpoint at the end of the last trace statement I get the data, but how do I display this data in a list?
                     creationComplete="handleCreationComplete(event)">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
              <s:HTTPService id="imageService"
                             url="http://www.cotrip.org/xml/cameras.xml"
                             resultFormat="e4x"
                             result="handleImageResult(event)"/>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.collections.XMLListCollection;
                  import mx.events.FlexEvent;
                  import mx.rpc.events.ResultEvent;
                  [Bindable]
                  private var ImageLocation:XMLListCollection;
                  private function handleCreationComplete(event:FlexEvent):void {
                      imageService.send();
                  private function handleImageResult(event:ResultEvent):void {
                      var cameraXML:XML = event.result as XML;
                      var cameraNS:Namespace = cameraXML.namespace("camera");
                      var cameraList:XMLList = cameraXML.cameraNS::Camera;
                      for each (var camera:XML in cameraList) {
                          trace("id: " + camera.cameraNS::CameraId);
                          var views:XMLList = camera.cameraNS::CameraView;
                          for each (var view:XML in views) {
                              trace("ImageLocation: " + view.cameraNS::ImageLocation);
          </fx:Script>
              <s:List left="200" height="40" dataProvider="{imageService}"/>
      </s:Application>
        • 1. Re: Flex e4x XML can't figure out?
          Flex harUI Adobe Employee
          If myXML is a variable referencing the XML and the camera namespace is “open”, just try
              myXML..ImageLocation
          • 2. Re: Flex e4x XML can't figure out?
            Log Home Level 1
            I guess that gets me 1/2 way there, but now, how do I make myXML a variable feferencing the XML?
            • 3. Re: Flex e4x XML can't figure out?
              Sorry, I didn’t see that you posted code.  I think the code needs to look like:
                              imageLocation = new XMLListCollection(cameraXML..cameraNS::ImageLocation);
              The list should be bound to imageLocation and not imageService.
              And you may need a labelFunction that looks like:
                  private function xmlLabelFunction(data:Object):String
                      return data.text();
