3 Replies Latest reply on Nov 5, 2011 9:41 PM by Rick Gerard
    Import Premiere Pro Sequence Problems
    JustinDashing
      Hello, I am new to using CS for video editing so forgive me if this seems very basic.
      What I am trying to do, is bring a sequence from Premiere Pro into After Effects so that I can jazz it up with some compositing and effets etc.  I went to File>Dynamic Link and imported my premiere sequence.  It shows up in my project panel, and double clickign it I can view it as normal.  But when I try to drag it into my timeline panel to make a comp, nothing happens.  I have tried draging it to the "create new comp" button within the project panel, and all it does is create an empty comp.  Am I doing something wrong?  I am using Mac OS X 10.7.2
        • 1. Re: Import Premiere Pro Sequence Problems
          Just open up the comp. It should do that automatically.
          • 2. Re: Import Premiere Pro Sequence Problems
            JustinDashing Level 1
            When I do this, I just get an empty comp.
            • 3. Re: Import Premiere Pro Sequence Problems
              I think you're going about this all wrong. If you go to Adobe Dynamic Link and pick Import Premiere Pro Sequence you get a movie not a composition.
              I don't think that's what you want.
              If you go to File>Import>Premiere Pro Project you get all of the footage, the bins, and either all of the sequences as compositions or a selected sequence as a composition. Only cross dissolves and cuts come across but the AE project can quickly become unmanageable if there are lots of cuts. I cut a feature film last year in Premiere Pro and there were just a little over 3000 edits. Can you imagine working on a comp with 3000 layers???
              The project looks like this:
              The only difference between importing a movie and importing a Premiere Pro Project using dynamic link is that you can go back into Premiere Pro and re-edit the movie, then bounce back into AE and see the edits without rendering the Premiere Pro sequence. It's not at all useful to do what you describe in your original question. I didn't read carefully when I posted the first answer.
              My usual workflow, in fact the workflow used in the project I'm showing here, is to go to one or a few of the shots I'm working on in Premiere Pro, select them then right click on the selected shots and choose Replace with After Effects Composition. This enables AE, allows me to concentrate on the sequence that needs the work in AE, keeps my AE projects very manageable, and lets me work faster and more efficiently. This runway show First Cut had about 15 effects shots, each requiring only about 3 or 4 layers. If I had imported the entire PPro project I would have had about 500 layers to sort out and the comp would have been completely unmanageable.
