• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RH8: Inserting a paragraph into a multi-level list
Explorer ,
Nov 06, 2011 Nov 06, 2011
I created a multi-level list for various levels of steps in a procedure (each step can have substeps, and substeps can have one more layer of substeps). Each step and substep must have a result, for which I've created a para style.
For example:
1.  Step to perform an action
     Result 1
2.  Step to perform an action
     Result 2
3.  Step to perform an action do the following:
     a. Do an action
         Result a
     b. Do an action
         Result b
4. And so on...
The problem is that after hitting ENTER after Substep a, Substep b automatically appears so I cannot add Result a.
The only way I've found is to go to the HTML view and manually remove the rh_list_start and rh_list_end tags.
Any suggestions?
Views
947
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Nov 10, 2011 Nov 10, 2011
Hold SHIFT while pressing ENTER.  It makes a <br> instead of a <p>.
Votes
Translate
Translate
Explorer ,
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks. I figured it out a few days ago and forgot to close this thread. My bad.
Votes
Translate
Translate
Report
Report
Explorer ,
This doesn't give you the exact results if you have paragraph spacing above or below. I have never thought this was an ideal solution, but there isn't any other, which is why I don't use automatic numbering or bulleting.
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 11, 2011 Nov 11, 2011
You can fix that in your CSS like this for example:
li br{
     margin:8px 0px;
That will only stlye breaks that are within LI tags.
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 12, 2011 Nov 12, 2011
Thanks. This is a tip I have needed!
~Margaret
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks. I noticed the spacing problem but figured I would just have to live with the lesser of two evils.
But now that you mention it...
I created most bulltets in a multilevel list because of various formatting considerations. I found it easier to have one bullet list style and use the tab to position them as needed. So my bullets are not in an LI stye, but rather in a rh-list( _start) style. Any help is appreciated.
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 16, 2011 Nov 16, 2011
LATEST
Oh, rats. This doesn't work. It shows line spacing in the RoboHTML WYSIWYG editor, but not in a browser or compiled help. Once upon a time, there was a nice "Skip Numbering" feature, but that is gone now.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
