12 Replies Latest reply on Nov 8, 2011 8:49 AM by Zolotoj
    Label as custom Item renderer
    Zolotoj Level 3
      Here is my Label custom renderer:
      package
          import spark.components.Grid;
          import spark.components.Label;
          import spark.components.gridClasses.GridColumn;
          import spark.components.gridClasses.IGridItemRenderer;
          public class LabelItemRenderer extends Label implements IGridItemRenderer
              public function LabelItemRenderer()
                  //TODO: implement function
                  super();
              public function get grid():Grid
                  return null;
              public function get rowIndex():int
                  return 0;
              public function set rowIndex(value:int):void
              public function get down():Boolean
                  return false;
              public function set down(value:Boolean):void
              public function get dragging():Boolean
                  return false;
              public function set dragging(value:Boolean):void
              public function get hovered():Boolean
                  return false;
              public function set hovered(value:Boolean):void
              public function get label():String
                  return null;
              public function set label(value:String):void
              public function get selected():Boolean
                  return false;
              public function set selected(value:Boolean):void
              public function get showsCaret():Boolean
                  return false;
              public function set showsCaret(value:Boolean):void
              public function get column():GridColumn
                  return null;
              public function set column(value:GridColumn):void
              public function get columnIndex():int
                  return 0;
              public function prepare(hasBeenRecycled:Boolean):void
              public function discard(willBeRecycled:Boolean):void
              public function get data():Object
                  return null;
              public function set data(value:Object):void
                  trace(value);
      Column definition:
      <editabledatagrid:EditableDataGridColumn
                          dataField="FamhistRelationshipCode"
                          editable="true"
                          headerText="Relationship">
                          <editabledatagrid:itemRenderer>
                              <fx:Component>
                                  <s:GridItemRenderer>
                                      <labelItemRenderer:LabelItemRenderer text="{data.FamhistRelationshipCode}"/>
                                  </s:GridItemRenderer>
                              </fx:Component>
                          </editabledatagrid:itemRenderer>
                      </editabledatagrid:EditableDataGridColumn>
      Initially datgrid is empty. At some point a row is added to its dataProvider, Why trace in set data would not trace?
        • 1. Re: Label as custom Item renderer
          saisri2k2 Level 4
          remove the <s:GridItemRenderer it is acting as a wrapper for the actual  itemrenderer and it is not alowing the data to be set onto tthe actual renderer ie., the label.
          <labelItemRenderer:LabelItemRenderer text="{data.FamhistRelationshipCode}" data={data}/> add the change i've made here, hopefully it has to work.
          Are you able to see the text ?
          • 2. Re: Label as custom Item renderer
            Zolotoj Level 3
            Here is what I am gettiing.
            I have a binding warning on data="{data}".  Also if I use the renderer at all then data property will be = null during ending of a data editing session and SDK will crash. I tried to use the renderer without setting data still the same. Here is my item renderer:
            package
                import flash.events.Event;
                        super();
                        return null;
                        return 0;
                        return false;
                        return false;
                        return false;
                        return null;
                        return false;
                        return false;
                        return null;
                        return 0;
                        return null;
                        trace(value);
            Am I missing something here?
            Thanks for the help.
            • 3. Re: Label as custom Item renderer
              Zolotoj Level 3
              I was able to take of data being null. But now, when I end the editing session my item renderer (or what ever that might be) shows [object Object].
              Any idea?
              • 4. Re: Label as custom Item renderer
                saisri2k2 Level 4
                on override set data() set the text = data.someLabelToDisplay.
                • 5. Re: Label as custom Item renderer
                  saisri2k2 Level 4
                  I've a suggestion for you, if any of the above stuff does not work, since you are using flex > 4.0, i'll go with the default <S:ItemRenderer instead of the label which you are trying to get to work as a itmrenderer. and then i'll add this label as a child to this renderer. I would remvoe the wrapping <s:DAtaGridRenderer also.
                  • 6. Re: Label as custom Item renderer
                    Zolotoj Level 3
                    Yes, I am trying to.
                    But data.someLabelToDisplay in the debugger is already [object Object]
                    • 7. Re: Label as custom Item renderer
                      Zolotoj Level 3
                      Hre is what I have:
                                             <fx:Component>
                                                      <labelItemRenderer:LabelItemRenderer text="{data.FamhistRelationshipCode}" data="{data}"/>
                                              </fx:Component>
                      Is that what you mean? Also what about this data binding (data="{data}") warning? Is it OK? May be that's why it's not working.
                      • 8. Re: Label as custom Item renderer
                        Zolotoj Level 3
                        And this simply not compiling:
                                                <fx:Component>
                                                        <s:Label text="{data.FamhistRelationshipCode}" data="{data}"/>
                                                </fx:Component>
                        Cannot resolve attribute 'data' for component type spark.components.Label.
                        • 9. Re: Label as custom Item renderer
                          saisri2k2 Level 4
                                                 <fx:Component>
                                                          <labelItemRenderer:LabelItemRenderer //removed code here/>
                                                  </fx:Component>
                          in the renderer
                                        super.data = value;
                                         this.text = data.FamHistRelationshipCode; // if this is [object object] then try to see if this is object or text
                                         trace(value);
                                                  <fx:Component>
                                                  </fx:Component>
                          the above code is not required(which is striked off)
                          Message was edited by: saisri2k2
                          • 10. Re: Label as custom Item renderer
                            Zolotoj Level 3
                            If you say that the following is not needed then how to override set data?
                                                    <fx:Component>
                                                    </fx:Component>
                            • 11. Re: Label as custom Item renderer
                              saisri2k2 Level 4
                                                     <fx:Component>
                                                      </fx:Component>
                              this stays as is in the datagrid
                              LabelItemRenderer.mxml below. and nothing else.
                              <s:ItemRenderer xmlns:s="">
                              <script>
                              // all your setters/getters go hre and then
                                            super.data = value;
                                             trace(value);
                              </script>
                              <s:Label text={data.something}/?
                              </s:ItemRenderer>
                              • 12. Re: Label as custom Item renderer
                                Zolotoj Level 3
                                I dont even have to use an Item Renderer.
                                It looks like the problem was with returning data from the Item Editor.
                                Thank you very much for the help.
