2 Replies Latest reply on Nov 8, 2011 7:28 AM by Don Kerr
    List selectedItem inside GridItemEditor
    Don Kerr Level 3
      I have a List inside a GridItemEditor.  To make it reusable for many columns, I make the dataProvider and labelField variables, since they are different for each column. The labelField of the List typically matches the column.dataField .
      [Bindable] public var dp:ArrayCollection;
      [Bindable] public var lf:String;
      <s:TextInput id="t"  prompt="filter as you type" change="t_changeHandler(event)"/>
      <s:List id="l"   dataProvider="{dp}" labelField="{lf}">
      How do I return the value of the labelField property in l.selectedItem?  Typically, I have a fixed property (e.g. list.selectedItem.firstName), but in this case I need it to return the value of labelField as it varies by column.
      override public function get value():Object {
        return l.selectedItem[labelField]  ????; // don't know the syntax?
      override public function save():Boolean
                                                        data[column.dataField] = value;
      Don
