2 Replies Latest reply on Nov 8, 2011 7:07 AM by kglad
    How can I restart or load function
    jurzyna Level 1
      I am creting an application that containts 3 seperate slideshows inside movie clips, when one slideshow finishes the other starts. I do this by triggering the function inside the other movieclip slideshow ( _root.slideshow2.startSlideshow(); ) and stopping the currently running function startSlideshow = null; inside existing slide. It works until it gets to the 3rd slideshow and than everything freezes because all the functions where deleted. My question is how can I restart or reload the sam function again?
        • 1. Re: How can I restart or load function
          relaxatraja Level 5
          can you show the code?
          • 2. Re: How can I restart or load function
            use another variable to reference startSlideshow so you can alternately null and then re-define that variable.  for example, define startSlideshow:
            function startSlideshow(){
            //whatever
            and don't ever directly call it.  use another variable to reference startSlideshow:
            var startSS:Function = startSlideshow;
            when you want that code to executed, null startSS when you want that code to stop
            startSS = null
            and then when you want it to restart,
            startSS = startSlideshow
            make sure none of your nested code calls startSlideshow directly.  all those old references to startSlideshow need to be changed to startSS.
