4 Replies Latest reply on Nov 8, 2011 2:16 AM by Peter Spier
    Over Stretched Photos ?
    Marcus Tylor000000
      Hello, how do I know when the photos in the document have been stretched beyond their native size ? The info in the tools palet always says they are 100%. I am use to Quark which was easy to see this. Any ideas how I can find out which photos need redoing please ? I have 450 photos of all shapes and sizes arrggg...
      Thanks in advance !
        • 1. Re: Over Stretched Photos ?
          Techi Panda Level 2
          Hi Marcus Tylor000000
          I assume this will help you
          myGraphics = app.documents[0].allGraphics;
          for (var j = myGraphics.length - 1; j >= 0; j--)
                  var Hscale=myGraphics[j].horizontalScale;
                  var Vscale=myGraphics[j].verticalScale;
                      if(Hscale!=100)
                              try {app.layoutWindows[0].zoomPercentage = 100 } catch (e) {};
                              alert("This image is Horizontally scaled " + Hscale + " percent");
                              app.selection = myGraphics[j];
                      if(Vscale!=100)
                              alert("This image is Vertically scaled"  + Vscale +  "percent");
          • 2. Re: Over Stretched Photos ?
            Marcus Tylor000000 Level 1
            Ok, silly me think I have found it by selecting the second pointer down and double clicking woooo...
            • 3. Re: Over Stretched Photos ?
              John Hawkinson Level 5
              It does make me wonder though -- is there really any point in ID displaying the 100% values that repreent the size of the frame? Does it do anything other than confuse people and add an extra step to check the sizes of the image?
              I suppose the counterargument to changing it is that then you would not easily be able to resize that frame (change 100% to 50%). I feel like there's a better answer out there, though.
              • 4. Re: Over Stretched Photos ?
                There's that, and if you change your prefs to Adjust Scaling Percentage ini the When Scaling section of the General tab, the scaled size of the frame is shown instead of 100%, but oter things happen that you might not like.
