0 Replies Latest reply on Nov 8, 2011 2:57 AM by kkingg
    Looking for a script to connect bodytext to footnote and cross-references
      Need to do the following:
      I was provided with separate (tagged-text) files: bodytext, (foot)notes and cross-references. Now I am looking for a solution (script?) that can do the following:
      to restore the connection between the body-text, the footnotes and te cross-references after placing these in a document in Indesign.
      The cross-references should appear (in anchored text-frames) in the margin and the notes in a separate frame at the bottom of the page. If possible in the same way as footnotes in Indesign appear, but in a separate frame to be able to do some more formatting than native footnotes would accept.
      I have tested the plugin: Side Heads from InTools, and tis works well with Indesign files tthat contain footnotes. But this doesn't work with separately placed footnotes from a tagged-text-file, as they re not knotted together.
      I can't do any scripting myself.
      I would appreciate any help, and I am looking forward to your response...
