7 Replies Latest reply on Nov 9, 2011 9:02 PM by relaxatraja
    How to activate something inside the function outside function? - class
    McbainGames11 Level 2
      Hey,
      I need to activate some lines of code inside a function because that is where the object name has been made.
      Would a boolean work well? If so how exactly would i implement it? I tried booleans but had no success because i am not experienced with them...
      Heres some code:
      public var myboolean:Boolean = new Boolean();
      public function Function_One()
      public function Function_Two()
      var myObject:DisplayObject = new ObjectClass();
      //I want the object name 'myObject to be used in Function_One() but i can't so whats a good method to fix this?
      I was thinking a boolean could be useful so it could 'set off' my lines of code with an if statement of a boolean. But no Luck..
      Or is there a better way to achieve this?
      Thanks.
        • 1. Re: How to activate something inside the function outside function? - class
          relaxatraja Level 5
          public var myObject:DisplayObject;
               myObject = new ObjectClass();
          Try this
          • 2. Re: How to activate something inside the function outside function? - class
            // I can't move this line of code because what i want to implement the solution i get with this basic code into my real class
            // what i want is to remove the object by using removeChild(myObject); in a function outside of this class...How to do this?
            • 3. Re: How to activate something inside the function outside function? - class
              relaxatraja Level 5
              What I have shown is able to access the variable outside of the function, if you declare the variable with var within a function, then the scope of the variable only within that function. Otherwise give a try like below:
              myObject.name="testmc";
              addChild(myObject);
              public function Function_remove(){
                  removeChild(MovieClip(getChildByName("testmc"));
              play with getChildByName and getChildAt.
              • 4. Re: How to activate something inside the function outside function? - class
                Still can't get it to work, here's my script now what exactly do i do?
                package
                    import flash.display.MovieClip;
                    import flash.events.Event;
                    import flash.events.MouseEvent;
                    import flash.events.TimerEvent;
                    import flash.utils.Timer;
                    import flash.display.DisplayObject;
                    public class Main extends MovieClip
                        public var enemyA:Array = [];
                        public var birdA:Array = [];
                        public var MAX_ENEMIES:int = 10;
                        public var gap:int = 100;
                        public var timer:int = 0;
                        public var time_limit:int = 10;
                        public var TimerSpeed:uint = 1000;
                        public var MyTimer:Timer = new Timer(TimerSpeed);
                        public var TheBird:BirdChar = new BirdChar();
                        public function Main()
                            // Constructor Code
                        public function activateGameControls()
                            createEnemyF();
                            createBirdF();
                            this.addEventListener(Event.ENTER_FRAME,loopF);
                            MyTimer.addEventListener(TimerEvent.TIMER,TimerHandler);
                            MyTimer.start();
                        public function deactivateGameControls()
                            removeChild(MovieClip(getChildByName("enemy_mc"))); //code you suggested...<<
                            addChild(TheBird);
                            removeChild(TheBird);
                            MyTimer.removeEventListener(TimerEvent.TIMER,TimerHandler);
                        public function createEnemyF()
                            for (var i:int = 0; i < MAX_ENEMIES; i++)
                                var enemy:DisplayObject = new Enemy();
                                enemy.x = Math.random() * stage.stageWidth - enemy.width;
                                enemy.y =  -  i * (gap + enemy.height) - 30.65;
                                addChild(enemy);
                                //trace(enemy.x, enemy.y);
                                enemyA.push(enemy);
                                enemy.name = "enemy_mc"; //code you suggested...<<
                        public function createBirdF()
                            TheBird.x = 270.95;
                            TheBird.y = 350.95;
                            birdA.push(TheBird);
                            addChild(TheBird);
                        public function loopF(event:Event)
                            updateEnemyPositionsF();
                            updateBirdPositionsF();
                            hitTestF();
                        public function updateEnemyPositionsF()
                            for (var i:int = 0; i < enemyA.length; i++)
                                var enemy:DisplayObject = enemyA[i] as DisplayObject;
                                //trace("this is your enemy #" + i + ": " + enemy + ", do whatever with him.");
                                enemy.y +=  2;
                                if (enemy.hitTestObject(TheBird))
                                    //trace("BAAAM! Enemy #" + i + " hit whatever he was supposed to hit.");
                                    gotoAndPlay(5);
                                    deactivateGameControls();
                                    addChild(enemy);
                                    removeChild(enemy);
                        public function updateBirdPositionsF()
                            TheBird.x = mouseX;
                        public function hitTestF()
                            /*if (TheBird.hitTestObject(enemy))
                            gotoAndPlay(5);
                            trace('The Bird Hit Enemy 1');
                        function TimerHandler(event:TimerEvent)
                            timer +=  1;
                            if ((timer == time_limit))
                                gotoAndPlay(5);
                                trace('Level One is Completed');
                • 5. Re: How to activate something inside the function outside function? - class
                  relaxatraja Level 5
                  Try with method 1:
                  if (getChildByName("enemy_mc")!=null) removeChild(getChildByName("enemy_mc"));
                  Try with method 2:
                  for (i=this.numChildren-1;i>=0;i--){
                         trace(bg.getChildAt(i).name);  //make sure the name you specified on stage
                         if (this.getChildAt(i).name=="enemy_mc") bg.removeChildAt(i);
                  place a trace statement and identify first whether it retrieve the movieclip "enemy_mc"
                  • 6. Re: How to activate something inside the function outside function? - class
                    It worked(Method 1)! Never thought i would love 2 lines of code this much
                    Cheers, I will remember this method for next time i get into a situation like this!
                    Question Closed.
