3 Replies Latest reply on Nov 8, 2011 6:24 PM by Tatsu_
    I want to get the multiple selected layers name.
    Tatsu_
      The "activeDocument.activeLayer" command returns only one layer name. Even if multiple layers were selected.
      Can I solve the problem?
        • 1. Re: I want to get the multiple selected layers name.
          Paul Riggott Level 6
          Please try this example...
          #target Photoshop
          app.bringToFront();
          main();
          function main(){
          if(!documents.length) return;
          var selectedLayers = getSelectedLayersIdx();
          var selectedLayersNames =[];
          for(var a in selectedLayers){
              selectedLayersNames.push(getLayerNameByIndex( Number(selectedLayers[a]) ));
          alert("Number of Layers selected = " + selectedLayers.length + "\rLayer Names = " + selectedLayersNames.toString());
          function getLayerNameByIndex( idx ) {
              var ref = new ActionReference();
              ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "Nm  " ));
              ref.putIndex( charIDToTypeID( "Lyr " ), idx );
              return executeActionGet(ref).getString(charIDToTypeID( "Nm  " ));;
          function getSelectedLayersIdx(){
                var selectedLayers = new Array;
                ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                var desc = executeActionGet(ref);
                if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                   desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                    var c = desc.count
                    var selectedLayers = new Array();
                    for(var i=0;i<c;i++){
                      try{
                         activeDocument.backgroundLayer;
                         selectedLayers.push(  desc.getReference( i ).getIndex() );
                      }catch(e){
                         selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                 }else{
                   ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                   ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                   try{
                      selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
                   }catch(e){
                      selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
                return selectedLayers;
          function selectLayerByIndex(index,add){
           add = (add == undefined)  ? add = false : add;
              ref.putIndex(charIDToTypeID("Lyr "), index);
              var desc = new ActionDescriptor();
              desc.putReference(charIDToTypeID("null"), ref );
                 if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
                desc.putBoolean( charIDToTypeID( "MkVs" ), false );
             try{
              executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
          }catch(e){}
          • 2. Re: I want to get the multiple selected layers name.
            Michael L Hale Level 5
            What version of Photoshop are you using? With newer versions you can determine multiple selected layers using Action Manger.
            EDIT: Paul beat me to this with the AM code. But it will not work with older version of Photoshop because they don't have the needed document descriptor key.
            • 3. Re: I want to get the multiple selected layers name.
              Tatsu_ Level 1
              >Paul
              I got the layers name.
              You have helped me greatly.
              I appreciate your assistance indeed.
              >Michael
              I use CS3.The Paul's script running well !
