12 Replies Latest reply on Dec 1, 2011 10:27 AM by Code Girl
    Single Column Datagrid
    Code Girl Level 1
      I have a combobox with a list of class a
      when a record is selected in the ComboBox then the data grid is populated with a list from a of type class b which basically is a id and name
      Since I do not want to list the id field I only want to to list the name field but if someone edits the list I want another combobox to pop up with a list of class b.
      When someone selects from that list, I want to return the class b.
      The problem is that the row is class b and the column is the name and not the class b and so the returned item is not compatible.
      How can I assign the selected b to the row instead of the column?
      Or, is there something else besides a datagrid which has headers, can be sorted, and has itemeditors so I can add the combo box or drop down list.
        • 1. Re: Single Column Datagrid
          Code Girl Level 1
          Wondering why nobody has answered my last few questions?
          Also, I it was a dropdownlist instead of a combobox but thats does not change the question.  I have tried so many angles and still do not have an answer.
          • 2. Re: Single Column Datagrid
            Claudiu Ursica Level 4
            There is a labelFunction and an itemRendererFunction property for lists and grids you might be able to hook up logic in there based on your selections.
            C
            • 3. Re: Single Column Datagrid
              Code Girl Level 1
              I am already using these functions.  but thank you for your suggestion.  Its possible what I want to do can not be done because of the property constraint in the datagridcolumn.  Adobe may need to make a change to allow "this" as the dataField or create a datagrid single column component.
              • 4. Re: Single Column Datagrid
                Why don't you use a list or datagroup instead if there is only one column?
                C
                P.S.
                I did not understand 100% what you are trying to achieve.
                • 5. Re: Single Column Datagrid
                  Code Girl Level 1
                  If I understand it correctly, you can not attach an item editor that contains a dropdownlist  on a list.  Am I wrong?   I wonder if a data group does or not?
                  • 6. Re: Single Column Datagrid
                    Code Girl Level 1
                    Found a work around solution but really could use a cleaner one.
                    First do not assign a datafield in the datagridcolumn.  In the drop down list close handler update the list that services the Datagrid directly using the outerdocument.bs[outerdocument.dg.selectedIndex] = your objec b.  This did work.  But not too clean.
                    • 7. Re: Single Column Datagrid
                      Flex harUI Adobe Employee
                      Post a 20-line test case.
                      • 8. Re: Single Column Datagrid
                        I have done in the past list with custom renderer where fields where steppers. Code was written by hand but it worked...
                        You had to handle a lot including tabbing but at the end of the day was what we needed.
                        • 9. Re: Single Column Datagrid
                          Code Girl Level 1
                          The dataprovidor is a list of Class B inside Class A
                          Class A
                          List<Class B>
                          Class B
                          int id
                          String name
                          The dropdownlist is a list of all Class B's
                          valueObject:A a
                          valueObject:B b
                          DataGrid id="bDG"
                                    dataProvider="{a.bs}"
                                    editable="true"
                               Column
                                    DataColumn dataField
                                                        labelFunction="b.name"
                                                        editable="true"
                                                        editorDataField="value"
                          // notice no datafield property
                                         itemEditor
                                              Script
                                                   function get value:B
                                                        return b
                                                   function ddl closehandler
                                                        b = ddl.selectedItem as B
                                                        outerDocument.a.bs[outerDocument.bDG.selectedIndex] = b
                                              Declaration
                                                   valueObject:B id b
                                              DropDownList
                                                   prompt="b.name"
                                                   dataProvider="bList"
                                                   labelField="name"
                          • 10. Re: Single Column Datagrid
                            That’s not a test case, that’s a snippet.  I don’t have time to build up a test case around snippets.  Post an application that I can cut, paste, compile and run.  Try to keep it to as few lines as possible.
                            • 11. Re: Single Column Datagrid
                              Code Girl Level 1
                              Sorry so big.  Didn’t know how to convert java classes to as since FB did it for me.
                              • 12. Re: Single Column Datagrid
                                Code Girl Level 1
                                xmlns:mx="library://ns.adobe.com/flex/mx"
                                xmlns:valueObjects="valueObjects.*"
                                width="100%" height="100%">
                                <fx:Script>
                                <![CDATA[
                                import mx.collections.ArrayCollection;
                                import mx.events.FlexEvent;
                                protected function aCBLabel(item:Object):String
                                if (item != null)
                                return item.name;
                                else
                                return "";
                                protected function bDG_creationCompleteHandler(event:FlexEvent):void
                                bDG.selectedIndex = 0;
                                protected function bFormat(item:BDto, column:DataGridColumn):String
                                if (item != null)
                                return item.name;
                                else
                                return "";
                                </fx:Script>
                                <fx:Declarations>
                                <valueObjects:ADto id="aDto"/>
                                <valueObjects:BDto id="bDto"/>
                                <s:ArrayCollection id="aList">
                                <valueObjects:ADto>
                                <valueObjects:id>1</valueObjects:id>
                                <valueObjects:name>a1</valueObjects:name>
                                <valueObjects:bs>
                                <valueObjects:BDto>
                                <valueObjects:name>b1</valueObjects:name>
                                </valueObjects:BDto>
                                <valueObjects:BDto>
                                <valueObjects:id>2</valueObjects:id>
                                <valueObjects:name>b2</valueObjects:name>
                                </valueObjects:bs>
                                </valueObjects:ADto>
                                <valueObjects:ADto>
                                <valueObjects:name>a2</valueObjects:name>
                                </s:ArrayCollection>
                                <s:ArrayCollection id="bList">
                                <valueObjects:BDto>
                                <valueObjects:BDto>
                                <valueObjects:BDto>
                                <valueObjects:id>3</valueObjects:id>
                                <valueObjects:name>b3</valueObjects:name>
                                </fx:Declarations>
                                <fx:Binding source="aCB.selectedItem as ADto" destination="aDto"/>
                                <s:Form id="AForm" width="700" height="170">
                                <s:layout>
                                <s:BasicLayout/>
                                </s:layout>
                                <s:HGroup x="0" y="50" width="670" height="60">
                                <s:Label height="25" fontWeight="bold" text="Find an A" verticalAlign="middle"/>
                                <s:ComboBox id='aCB'
                                prompt="Enter or Select an A Name"
                                labelFunction="aCBLabel"
                                x="110" y="10" width="375">
                                <mx:ArrayCollection id="asList" list="{aList}"/>
                                </s:ComboBox>
                                </s:HGroup>
                                </s:Form>
                                <mx:DataGrid id="bDG" x="10" y="140" width="450" height="200"
                                editable="true"
                                dataProvider="{aDto.bs}"
                                creationComplete="bDG_creationCompleteHandler(event)">
                                <mx:columns>
                                <mx:DataGridColumn id="bNameDC"
                                headerText="As Bs"
                                editable="true"
                                labelFunction="bFormat"
                                width="150">
                                <mx:itemEditor>
                                <fx:Component>
                                <mx:Canvas>
                                <fx:Script>
                                <![CDATA[
                                import spark.events.DropDownEvent;
                                [Bindable]
                                public var bs:ArrayCollection;
                                protected function sdd_InitializeHandler(event:FlexEvent):void
                                bs = outerDocument.bList;
                                bDto = outerDocument.bDG.selectedItem as BDto;
                                if (bDto != null)
                                var t:BDto;
                                for (var i:int = 0; i<bs.length; i++)
                                t = bs[i];
                                if (bDto.id == t.id)
                                ddl.selectedIndex = i;
                                break;
                                ddl.openDropDown();
                                public function get value():BDto
                                return bDto
                                protected function ddl_closeHandler(event:DropDownEvent):void
                                bDto = ddl.selectedItem as BDto;
                                outerDocument.aDto.bs[outerDocument.bDG.selectedIndex] = bDto;
                                </fx:Script>
                                <fx:Declarations>
                                <!-- Place non-visual elements (e.g., services, value objects) here -->
                                </fx:Declarations>
                                <s:DropDownList id="ddl"
                                width = "100%"
                                prompt="{bDto.name}"
                                dataProvider="{bs}"
                                labelField="name"
                                initialize="sdd_InitializeHandler(event)"
                                open="ddl.skin['dropDown'].owner = this"
                                close="ddl_closeHandler(event)">
                                </s:DropDownList>
                                </mx:Canvas>
                                </fx:Component>
                                </mx:itemEditor>
                                </mx:DataGridColumn>
                                </mx:columns>
                                </mx:DataGrid>
                                </s:Application>
