1 Reply Latest reply on Jan 31, 2012 1:49 PM by blorpblorp
    Importing DITA map into Robohelp 9 FATAL ERROR
    blorpblorp
      Hi!
      So I'm trying to import a DITA map into Robohelp 9. I have the 1.4.2.1 DITA Open Toolkit, and I am able start the import process. However, my map always seems to fail with the following error:
      Failed to parse the input file 'SampleDITAMap_PI.ditamap' due to below exception. Please correct the input base on the exception message.:SampleDITAMap_PI.ditamap Line 24:Element type "navtitle" must be declared.
      Number of Fatals : 1
      Number of Errors : 0
      I've notived that the map is connected to the map.dtd file, in which <navtitle> doesn't appear to be present. I've tries declaring the element in the code of the ditamap file as:
      <!ELEMENT topicmeta (navtitle*)>
      but then Robohelp says that topic meta cannot be declared twice. Will inserting some code about <navtitle> into the DTD file that defines <topicmeta> fix this?
      Is there some other way I can define <navtitle>? I've tried <!ELEMENT navtitle ([every single variation of what would be navtitle] separated by "|")
      Why do I have this issue in the first place?!
      Why isn't navtitle declared?!
      Dan
