6 Replies Latest reply on Jun 5, 2008 3:21 PM by johnAq
    Min/Max for Property List
    Level 7
      Okay, I can easily get the min/max value in a regular list like so:
      rList = [514,4567,123,67]
      put max(rList)
      --4567
      put min(rList)
      --67
      I can even do it for a basic property list:
      pList = [#A:514,#B:4567,#C123,#D:67]
      put max(pList)
      --4567
      put min(pList)
      --67
      The problem comes when I want to have a list of records, and get the max for
      a given property in each record, e.g.:
      pList = [[#val:514,<other data>],[#val:4567,<other data>],[#val:123,<other
      data>],[#val:67,<other data>]]
      Now what I want to be able to do is pull the record with the minimum/maximum
      for the #val property. The only method I can come up with involves a
      tedious repeat loop to search through the entire list, e.g.:
      n = pList[1].val
      repeat with i = 2 to pList.count
      if pList .val > n then n = pList.val
      end repeat
      put n
      --4567
      And sure, it works, but my actual lists have a lot more than 4 records, and
      this can be a slow process, much slower than the min()/max() functions.
      Another method that would be nice is if you could just rip the #val
      properties from every record and temporarily put them into their own list,
      and then get the min()/max() from that, but I don't know if that's possible
      either (without another tedious repeat loop). Is there another way to do
      this that I'm overlooking?
        • 1. Re: Min/Max for Property List
          johnAq Level 1
          There are a couple of options
          How is you list being compiled? Perhaps you could keep a parallel list running that popoluates in sync with the main one. This seems ineffecient, not unlike your repeat loops.
          Another option that will work is this. You currently have a main linear list of property lists. You could actually make this a property list, using the #val from each list as it's property in the main list.
          ie
          pList = [514:[#val:514,<other data>], 4567:[#val:4567,<other data>], 213:[#val:123,<other
          data>], 67:[#val:67,<other data>]]
          Now it's a simple matter of sorting this list (prop lists are sorted on the property), and you can then simply access the first or last entry to find min/max
          hth
          johnAq
          • 2. Re: Min/Max for Property List
            Lukewig Level 1
            This should work:
            pList = [[#val:514,<other data>],[#val:4567,<other data>],[#val:123,<other data>],[#val:67,<other data>]]
            pList.sort()
            put "min:" && pList[1][#val]
            put "max:" && pList[pList.count][#val]
            ... provided #val is always the first entry in every sub list.
            -- Luke
            • 3. Re: Min/Max for Property List
              Level 7
              > This should work:
              > pList.sort()
              This only works provided the list is sorted - other things depend on the
              list being in a specific order, so sorting it is not an option. It might
              work if I copied the list into a temporary list like:
              tList = pList
              tList.sort()
              etc.
              But as you said, this is assuming #val is the first in every sub list, which
              it isn't necessarily. (Each sub list has a number of values, and I may want
              to find the min or max for any one of those, not just the first.)
              • 4. Re: Min/Max for Property List
                Level 7
                > the
                > min/max
                Yeah, likewise, see my answer to Lukewig's post. I may need to sort by more
                than just one property, plus I can't sort the list, because it has to be in
                a defined order.
                • 5. Re: Min/Max for Property List
                  johnAq Level 1
                  If you copy to a temp list, you'll need to dupliate the list otherwise both variables will point to the same things, given the way Director wirks
                  tList = pList.duplicate()
                  tList.sort()
                  If you need to sort on more than one property, it sounds like you're back to keeping parallel lists
                  hth
                  johnAq
                  • 6. Re: Min/Max for Property List
                    johnAq Level 1
                    ... or repeat loops
                    hth
                    johnAq
