1 Reply Latest reply on Nov 9, 2011 12:40 AM by Mylenium
    Default "camera" when no camera layer is turned on
    Toomany3 Level 1
      What are the default camera settings when you don't have a camera layer in your composition?  When you turn layers on for 3D but don't have an actual camea layer, there's still a "camera" on, but not as a layer (otherwise how could you have an "active camera" view or be able to move in 3D space, etc.).
      What's the default mm settings specifically?
      I run into this every so often when I built a simple AE project without bothering to add a camera layer, but then the "simple" project gets a little more complicated and I need to add a "real" camera.  And since the settings of the invisible/default camera aren't the same as my new camera layer, all my composition in Z-space gets wiggy since it's not the same.
      Sometimes I just need to add a camera that's exactly the same as the invisible one I was using prior to adding a camera layer.
