1 Reply Latest reply on Nov 9, 2011 11:48 PM by Jens Eckervogt
    Problem with Source:Object and Output:File
    Jens Eckervogt
      Hello dear people,
      i have been found example like FileCompressTool.
      But i have been coded for conversors or decompilers.
      I have got error of File and FileStream
      Look at my picture
      http://www.funpic.de/photos/5/7/3/4/7/574375_45b95ed909_e.jpg
      I have been tried because my Adobe AIr Application has not error..
      How do i fix this error? Or i must run Adobe Air as Administrator Right?
      Code for Example:
      <mx:WindowedApplication
                title="Half-Life Map Decompiler"
                xmlns:mx="http://www.adobe.com/2006/mxml"
                layout="absolute"
                showStatusBar="false">
                <mx:Script>
                          <![CDATA[
                                    import com.valve.utils.mapEncorder;
                                    import flash.filesystem.File;
                                    private var bspSrc:File;
                                    private var mapDes:File;
                                    private function ChooseSrc():void
                                              if( bspSrc == null ) {
                                                        bspSrc = new File();
                                              bspSrc.addEventListener(Event.SELECT,  sourceSelectHandler);
                                              bspSrc.browseForOpen("Choose Half-Life 1 Bsp File", [new FileFilter("Half-Life 1 *.bsp", "*.bsp")]);
                                    private function sourceSelectHandler(event:Event):void
                                              bspSrcText.text = bspSrc.nativePath;
                                              StateLog.text = bspSrc.nativePath + " has been selected.";
                                    private function ChooseDes():void
                                              if ( mapDes == null ) {
                                                        mapDes = new File();
                                              mapDes.addEventListener(Event.SELECT, destinationSelectHandler);
                                              mapDes.browseForDirectory("Choose for decompiled Map file!");
                                    private function destinationSelectHandler(event:Event):void
                                              mapDesText.text = mapDes.nativePath;
                                              StateLog.text = mapDes.nativePath + " has been selected.";
                                    private function Decompile():void
                                              var bsp2map:mapEncorder = new mapEncorder();
                                              bsp2map.decompileBsp2map(bspSrc, mapDes);
                                              StateLog.text = "This Map File has been decompiled complety.";
                </mx:Script>
                <mx:Label left="10" top="10" text="Choose your bsp ( used by Half-Life 1 ):"/>
                <mx:TextInput id="bspSrcText" left="15" right="63" top="36"/>
                <mx:Button right="15" top="36" label="..." click="ChooseSrc()"/>
                <mx:Label left="10" top="70" text="Choose your decompiled map in your directory:"/>
                <mx:TextInput id="mapDesText" left="15" right="63" top="96"/>
                <mx:Button right="15" top="96" label="..." click="ChooseDes()"/>
                <mx:Label left="10" top="130" text="View with decompiled details:"/>
                <mx:Button right="98" top="128" label="Decompile" click="Decompile()"/>
                <mx:Button right="192" top="128" label="Clean log"/>
                <mx:TextArea id="StateLog" left="15" right="15" top="156" bottom="15"/>
                <mx:Button right="15" top="128" width="75" label="About..."/>
      </mx:WindowedApplication>
      And com.valve.utils.mapEncorder.as
                Valve Software
                Half-Life 1 - Maps
      package com.valve.utils
                import flash.filesystem.FileMode;
                import flash.filesystem.FileStream;
                import flash.utils.ByteArray;
                public class mapEncorder
                          public function decompileBsp2map(bspSrc:Object, mapDes:File):void
                                    if( bspSrc == null || mapDes == null ){
                                              throw new ArgumentError("Half-LIfe Bsp File and Half-Life Map File cannot be null.");
                                    var bspSrcByte:ByteArray;
                                    var mapFileTarget:File = new File(mapDes.nativePath);
                                    var fileTime:Date;
                                    if(bspSrc is File){
                                              var bspSrcFile:File = new File;
                                              if(bspSrcFile.exists || bspSrcFile.isDirectory){
                                                        throw new ArgumentError("If your bsp File is current version.");
                                              var bspFileStream:FileStream = new FileStream();
                                              bspFileStream.open(bspSrcFile, FileMode.READ);
                                              bspSrcByte = new ByteArray;
                                              bspFileStream.readBytes(bspSrcByte, bspFileStream.bytesAvailable);
                                              bspFileStream.close();
                                              if (mapFileTarget.isDirectory)
                                                        mapFileTarget = mapFileTarget.resolvePath(bspSrcFile.name + ".map");
                                                        fileTime = bspSrcFile.modificationDate;
                                              else if (bspSrc is ByteArray)
                                                        bspSrcByte = bspSrc as ByteArray;
        mapFileTarget = mapFileTarget.resolvePath("_decompiled.map");
                                                        fileTime = new Date();
                                              else
                                                        throw new ArgumentError("Bsp File must be complety.");
                                              var mapFileStream:FileStream = new FileStream();
                                              mapFileStream.open(mapFileTarget, FileMode.WRITE);
                                              mapFileStream.writeBytes(bspSrcByte);
                                              mapFileStream.close();
      Thank you for help - If you find an error than you can tell me. If it doesn't work than i will try Flash Builder with Running as Admin.
      Regards J. Eckervogt
        • 1. Re: Problem with Source:Object and Output:File
          Jens Eckervogt Level 1
          I have been found problem because i have been found issus of if (...) with !
          It is okay. I have been forgotten. I am sorry. Thanks.. I have been fixed this..
          It is true
          But is worng code :
                    Valve Software
                    Half-Life 1 - Maps
                                        var fileTime:Date;
                                        if(bspSrc is File){
                                                  else
          Replace to:
                    Valve Software
                    Half-Life 1 - Maps
                              public function decompileBsp2map(bspSrc:Object, mapFile:File):void
                                        if( bspSrc == null || mapFile == null ){
                                        var mapFileTarget:File = new File(mapFile.nativePath);
                                        var fileTime:Date;
                                        if(bspSrc is File){
                                                  var bspSrcFile:File = bspSrc as File;
                                                  if(!bspSrcFile.exists || bspSrcFile.isDirectory){
                                                  bspSrcByte = new ByteArray();
                                                  else
          Now it is working. Thanks!
