6 Replies Latest reply on Nov 10, 2011 5:35 PM by RjL190365
    Basic PC Spec for premiere
    petehandford
      Hello all,
      I am looking to view and edit some RED camera footage in CS5 and was wondering if anyone can recommend a decent PC spec that will be able to handle the footage ok?  I don't want to do it raw, just transcode the files and work that way.
      Budget is a major issue, but have spotted this and thought it might do the trick for a basic edit:
      Processor (CPU): INTEL SANDYBRIDGE Core I5 2500K SKT1155
      Motherboard: ASUS P8Z68-V LX With Z68 Chipset (NEW B3 VERSION)
      2xPCI-E (16x), 2xPCI(1x) & 3xPCI & 32GB RAM Support
      Memory: CORSAIR 8GB (4x2GB) DDR3 1600MHz i5 Memory Kit
      Hard Drive: 1TB SATA2 - 3Gbp/s, 7200 RPM
      Optical Drive: SAMSUNG BLU-RAY COMBO Drive, Blu-Ray Reader & DVDRW In One
      Graphics Card: Integrated HD 3000 Graphics @ 850mhz (1100MHz Turbo)
      Comes With VGA, DVI & HDMI Outputs As Standard
      Any thoughts or advice would be most appreciated.
      thanks
      pete
        • 1. Re: Basic PC Spec for premiere
          petehandford Level 1
          P.S. Further reading has revealed that I might be rather ambitious with this and am likely to need a 8 core system with a meaty graphics card.  Nevertheless if anyone can recommend a system or spec that works for them it would be really appreciated
          pete
          • 2. Re: Basic PC Spec for premiere
            Some ideas for a Desktop Video Editing PC
            http://www.adkvideoediting.com/
            -and http://forums.adobe.com/thread/877201?tstart=0
            You need an i7 CPU and AT LEAST 2 hard drives
            My 3 hard drives are configured as...
            1 - 320Gig Boot for Win7 64bit Pro and all program installs
            2 - 320Gig data for Win7 swap file and video project files
            When I create a project on #2 drive, the various work files follow,
            so my boot drive is not used for the media cache folder and files
            3 - 1Terabyte data for all video files... input & output files (*)
            (*) for 4 drives, drive 3 all source files & drive 4 all output files
            Search Microsoft to find out how to redirect your Windows swap file
            http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US
            • 3. Re: Basic PC Spec for premiere
              Harm Millaard Level 7
              At least i7-2700K, 16 GB memory, but preferably 32 GB with RED footage, at least 4 or more hard disks configured in raid0 or better, next to a decent boot disk, at least a nVidia GTX 560+ video card, and the basic PC is possibly there, provided a good gold label 850W PSU and Noctua/CoolerMaster or Prolimatech cooler and some overclocking. Remember to turm off the integrated graphics in the BIOS.
              • 4. Re: Basic PC Spec for premiere
                Scott Chichelli Level 3
                to add to the above
                it depends on your workflow.
                1 layer 2? 4?
                1/4 picture preview, 1/2 full?
                1-2 layers and 1/4 preview is fine with 2 sets raid 0 and 2600/2700 and 560/570 card 16gig ram
                4 layers+ and full picture really needs dual Xeon (2.93 or better) 12 core and 8 drive raid array 24 -48 gig ram
                Scott
                ADK
                • 5. Re: Basic PC Spec for premiere
                  Jim_Simon Level 8
                  For a project using RED media?  That's a bit incongruous.
                  • 6. Re: Basic PC Spec for premiere
                    RjL190365 Level 4
                    That PC is way underspecced for RED. For that resolution, plus the fact that such footage is extremely highly compressed and extremely high resolution to begin with, you really need a dual-Xeon 12-core/24-thread workstation with 24GB or more RAM, a discrete Quadro or a very high end GeForce GPU discrete hardware RAID controller and a four-drive or larger RAID 5. The above configuration listed in your original post is woefully inadequate even for standard-definition MPEG-2 DVD because it has only one hard drive total (editing requires three or more hard drives to function properly) and because that build lacks a discrete GPU (it has only integrated graphics).
                    One more thing about that proposed build: It isn't the CPU that's entirely to blame; it's the poorly balanced configuration that is to put most of the blame on. That system needs a minimum of three hard drives, a GeForce GTX 560 GPU and (if working with simple AVCHD) 16GB of RAM.
                    So in other words, for RED you have no choice but to spend a minimum of $6,000 USD on a PC for you to even work with such hi-rez, highly compressed media at all.
                    By the way, why did you buy a RED camera if you're going to be left with less than $1,000 to buy or build a PC to edit with?
