4 Replies Latest reply on Nov 9, 2011 11:59 AM by Owen_Alextoys
    Change cursor color
    Owen_Alextoys
      Hello,
           I've got a simple coloring book that I'm developing. I've got most everything working but I'm having trouble getting the cursor to pick up the active color from a color array.
      The cursor is a movieclip called "mycursor_mc" There is a movie clip inside this called "CursorFill". I am trying to get the "CursorFill" movie clip to change to the currentColour value from the dynamic property array index.
      This is the section I was working on but it's not working:
      var mycursor_mc:cursor = new cursor();
      addChild(mycursor_mc);
      var m = new CursorFill();
           mycursor_mc.addChild(m);
      Here's the whole Action script:
      //Array to hold the colours
      var colorArray:Array=new Array(0xE97DB1,0xF58240,0xF9ED41,0x82C34D,0x00B0F0,0x935CA4,0xFFFFFF);
      //A new instance of the colour transform class.
      var colorTrans:ColorTransform=new ColorTransform;
      var currentColor:int=0;
      //This adds the ovals on the stage with the corresponding colour from the array
      //and with the mouse click event.
      for (var i:int = 0; i < colorArray.length; i++) {
           var marker:Sprite = new Sprite();
           marker.y=500+i*50;
           var c = new MarkerFill();
           c.buttonMode=true;
           marker.addChild(c);
           colorTrans.color=colorArray[i];
           c.transform.colorTransform=colorTrans;
           c.addEventListener(MouseEvent.CLICK, ovalsClick);
           c.arrayIndex=i;
           var o:Outline = new Outline();
           marker.addChild(o);
           addChild(marker);
      //This creates a new instance of the cursor movie clip and adds it onto
      //the stage using the addChild method.
      //Hides the default cursor on the stage so it will not be shown.
      Mouse.hide();
      //Adds an event listener onto the stage with the enter frame event which
      //repeatedly executes the moveCursor function.
      stage.addEventListener(Event.ENTER_FRAME, moveCursor);
      //This function set the x & y positions of the custom cursor to the x & y positions
      //of the default cursor.
      function moveCursor(event:Event) {
        mycursor_mc.x=mouseX;
        mycursor_mc.y=mouseY;
      //This sets the currentColour value from the dynamic property array index.
      function ovalsClick(e:MouseEvent):void {
           currentColor=e.currentTarget.arrayIndex;
      //Adds the mouse click event to the holder.
      holder.addEventListener(MouseEvent.CLICK, holderHandler);
      //This function changes the colour of the movie clip inside
      //holder when it is clicked.
      function holderHandler (e:MouseEvent):void {
         for (var i:int = 0; i < holder.numChildren; i++) {
             if (holder.getChildAt(i).hitTestPoint(mouseX,mouseY,true)) {
                 colorTrans.color=colorArray[currentColor];
                 holder.getChildAt(i).transform.colorTransform=colorTrans;
        • 1. Re: Change cursor color
          Peter Celuch Level 4
          If you want to change the color of the cursor, you should be setting its colorTransform:
          var trans:ColorTransform = new ColorTransform();
          trans.color = 0xFF0000; // any color you want
          m.transform.colorTransform = trans;
          You are setting color to object being clicked (holder) instead of coloring the cursor.
          • 2. Re: Change cursor color
            Owen_Alextoys Level 1
            That's close but not quite what I'm looking for. I'm trying to get the cursor to change to the color of the last object clicked in the color array.
            trans.color=colorArray[currentColor]; // any color you want
            I tired this but it only picks up the first color in the array and dosen't change when I click the next one.
            • 3. Re: Change cursor color
              That's strange. Try tracing few things to make sure everything works as it should:
                   currentColor = e.currentTarget.arrayIndex;
                   trace(e.currentTarget, currentColor, colorArray[currentColor]);
                   trans.color = colorArray[currentColor];
              • 4. Re: Change cursor color
                Okay that worked. Thanks.
                -Owen
