1 Reply Latest reply on Jun 13, 2008 1:45 AM by anirudhs
    Using AIR with Ruby
    oshybrid
      How would I use Ruby with the Adobe AIR product, if I use FLEX or HTML/AJAX to make a Web App, compile it into AIR, but some of the back end data calculations and retrieval (not Rails) is done in Ruby?
        • 1. Re: Using AIR with Ruby
          anirudhs Level 2
          You'd need to communicate with your ruby backend via HTTP or sockets.If your backend is in a central server that all clients are going to connect, then there is no problem at all.
          Otherwise, if the ruby piece has to be on the same machine as the AIR app, you'll have to handle distribution of the ruby piece and the AIR piece separately.
