2 Replies Latest reply on Nov 9, 2011 11:44 PM by radzmar
    Adding Date/Time Field + X Number of Days - Basic Calculation Question
    ANDY.ALDRICH
      I am assuming this is a basic calculation question. New to Adobe LiveCycle Forms.
      I have a simple form containing a table. The table appears as such:
      Text Formatted as Date/Time FieldsHeader 3
      Monday user wil choose the beginning date (Date/Time) this is DateTimeField1
      Tuesdaythis should calculate DateTimeField1 + 1
      Wednesdaythis should calculate DateTimeField1 + 2
      Thursdaythis should calculate DateTimeField1 + 3
      Fridaythis should calculate DateTimeField1 + 4
      Saturdaythis should calculate DateTimeField1 + 5
      Sundaythis should calculate DateTimeField1 + 6
      Calculations are performed after the date is chosen for Monday. My mind tells me the simple calculation of DateTimeField1 + 1 is not going to work (and in fact doesn't!) as it needs to change Monday to a number first. I saw on another thread the following:
      Num2Date(Date2Num(Date(DateTimeField1), "DD.MM.YYYY")+7, "DD.MM.YYYY")
      Thought this was going to get me close. No cigars though!
      Any quick help is greatly appreciated. And since I am new to this, details about what needs to be changed would be great too!
        • 1. Re: Adding Date/Time Field + X Number of Days - Basic Calculation Question
          Steve L Walker Level 5
          The attached calculates dates for next six days starting Monday. It forces the start day to be a Monday also.
          // form1.page1.mon::exit - (FormCalc, client)
          var dayNum = Date2Num($.formattedValue,"MM/DD/YYYY")
          form1.page1.dayOfWeek.execCalculate()
          if (dayOfWeek.rawValue == "Mon") then
                    tues.rawValue = Num2Date(dayNum+1,"MM/DD/YYYY")
                    wed.rawValue = Num2Date(dayNum+2,"MM/DD/YYYY")
                    thurs.rawValue = Num2Date(dayNum+3,"MM/DD/YYYY")
                    fri.rawValue = Num2Date(dayNum+4,"MM/DD/YYYY")
                    sat.rawValue = Num2Date(dayNum+5,"MM/DD/YYYY")
                    sun.rawValue = Num2Date(dayNum+6,"MM/DD/YYYY")
          else
                    xfa.host.messageBox("The selected date is not a Monday.")
                    tues.rawValue = null
                    wed.rawValue = null
                    thurs.rawValue = null
                    fri.rawValue = null
                    sat.rawValue = null
                    sun.rawValue = null
          endif
          Steve
          • 2. Re: Adding Date/Time Field + X Number of Days - Basic Calculation Question
            radzmar Adobe Community Professional & MVP
            Here an addition for you date field.
            This FormCalc script in the exit:Event will check it the selected date is on a monday.
            If not it will go the days back until the last monday.
            var Selection = Date2Num($.formattedValue, DateFmt(2))
            var WeekDay = Num2Date(Selection, "E")
            var NewDate
            if (WeekDay eq 1) then
                      NewDate = Selection - 6
            elseif (WeekDay eq 3) then
                      NewDate = Selection - 1
            elseif (WeekDay eq 4) then
                      NewDate = Selection - 2
            elseif (WeekDay eq 5) then
                      NewDate = Selection - 3
            elseif (WeekDay eq 6) then
                      NewDate = Selection - 4
            elseif (WeekDay eq 7) then
                      NewDate = Selection - 5
            else
                      NewDate = Selection
            endif
            $ = Num2Date(NewDate, "EEE DD.MM.YYYY")
            Hope this helps, too.
