0 Replies Latest reply on Nov 9, 2011 10:31 PM by flexprabu
    Can't get correct (x1,y1,x2,y2)values in Draw Line between two points.
    flexprabu
      Hi fridends,
                  am trying to get correct value in draw line between two points and i have create some mistake in my code but i cant find that any one tel me how can i get correct x1,y1 and x2,y2 value in my out put of the program.i give the full source code and out put  below.
      Main Application
      <mx:Application frameRate="250" creationComplete="init()" xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" borderStyle="solid" backgroundGradientAlphas="[1.0, 1.0]" backgroundGradientColors="[#FFFFFF, #DFDFDF]">
                <mx:Script>
                          <![CDATA[
                                    import mx.controls.Alert;
                                    import san_comps.lineHandle;
                                    import san_comps.LineTool;
                                    import mx.core.Container;
                              private var xpos:int;
                              private var ypos:int;
                              private var h:int;
                              private var w:int;
                              private var rad:int;
                                    private function onMouseDown(event:MouseEvent):void
                                              xpos=circleHolder.mouseX;
                                              ypos=circleHolder.mouseY;
                                              circleHolder.removeEventListener(MouseEvent.MOUSE_DOWN,onMouseDown);
                                              circleHolder.addEventListener(MouseEvent.MOUSE_MOVE,onlineMove);
                                              circleHolder.addEventListener(MouseEvent.MOUSE_UP,onLineUp);
                                    private function onlineMove(event:MouseEvent):void
                                              xposn1=(event.currentTarget as Container).mouseX;
                                              yposn1=(event.currentTarget as Container).mouseY;
                                              circleHolder.graphics.clear();
                                              circleHolder.graphics.lineStyle(2,cPkr.selectedColor);
                                              circleHolder.graphics.moveTo(xpos,ypos);
                                              circleHolder.graphics.lineTo(xposn1,yposn1);
                                    private var gLine:LineTool;
                                    private var xposn1:int;
                                    private var yposn1:int;
                                    private function onLineUp(event:MouseEvent):void
                                              circleHolder.removeEventListener(MouseEvent.MOUSE_MOVE,onlineMove);
                                              circleHolder.removeEventListener(MouseEvent.MOUSE_UP,onLineUp);
                                              xposn1=circleHolder.mouseX;
                                              yposn1=circleHolder.mouseY;
                                              var a:int;
                                                var b:int;
                                                var rx:int;
                                                var ry:int;
                                              if(xposn1>xpos)
                                                          a=xposn1-xpos;
                                                          rx=xpos;
                                                else
                                                          a=xpos-xposn1;
                                                          rx=xposn1;
                                                if(yposn1>ypos)
                                                          b=yposn1-ypos;
                                                          ry=ypos;
                                                else
                                                          b=ypos-yposn1;
                                                          ry=yposn1;
                                              gLine=new LineTool();
                                              gLine.x1=0;
                                              gLine.y1=0;
                                              gLine.x2=uint(xposn1)-uint(xpos);
                                              gLine.y2=uint(yposn1)-uint(ypos);
                                              gLine.a=a;
                                              gLine.b=b;
                                              gLine.thickness=lt.value;
                                              gLine.color=cPkr.selectedColor;
                                              circleHolder.addChild(gLine);
                                              gLine.x=xpos;
                                              gLine.y=ypos;
                                              gLine.name="line";
                                              gLine.addEventListener(MouseEvent.CLICK,getCurrentObj);
                                              if(obj is LineTool)
                                                        LineTool(obj).showHandle=false;
                                              obj=gLine;
                                              LineTool(obj).showHandle=true;
                                    private function load(x1:int,y1:int,x2:int,y2:int,xval:int,yval:int):void
                                              gLine.x1=0;
                                              gLine.y1=0;
                                              gLine.x2=uint(x2)-uint(x1);
                                              gLine.y2=uint(y2)-uint(y1);
                                              gLine.x=xval;
                                              gLine.y=yval;
                                              gLine.name="line";
                                              if(obj is LineTool)
                                              obj=gLine;
                                    private var obj:Object;
                                    private function getCurrentObj(event:MouseEvent):void
                                              if(LineTool(obj).showHandle==true)
                                              obj=event.currentTarget as LineTool;
                                    public function remove(event:Event):void
                                              if(obj.name=='line')
                                                        circleHolder.removeChild(obj as LineTool);
                                    public var str:String;
                                    public function addXML():void
                                      str=obj.getLine();
                                      Txm.text=str;
                                    public function valueXY(event:MouseEvent):void
                                              Xva.text=(event.currentTarget as Canvas).mouseX.toString();
                                              Yva.text=(event.currentTarget as Canvas).mouseY.toString();
                </mx:Script>
                <mx:Canvas mouseMove="valueXY(event)" id="circleHolder" dropShadowEnabled="true" width="100%" height="600" borderStyle="solid" borderColor="#646566" x="0" y="0">
                </mx:Canvas>
                <mx:ColorPicker close="obj.color=cPkr.selectedColor;obj.update()" id="cPkr" labelField="Color"  x="40" y="608" selectedColor="#000000"/>
                <mx:Button click="circleHolder.addEventListener(MouseEvent.MOUSE_DOWN,onMouseDown)" x="427" y="608" label="Line" toolTip="Click And Draw Line"/>
                <mx:Button click="load(obj.x1,obj.y1,obj.x2,obj.y2,obj.x,obj.y)" x="484" y="608" label="Copy"/>
                <mx:Button click="remove(event)" label="Delete" x="546" y="608"/>
                <mx:NumericStepper value="1" minimum="1" maximum="5" change="obj.thickness=lt.value;obj.update();" id="lt" x="170" y="608"/>
                <mx:Button click="addXML()"  x="618" y="608" label="XML"/>
                <mx:Button x="101" y="651" label="Clear" click="Txm.text=&quot; &quot;"/>
                <mx:TextArea  x="101" y="680"  width="840" height="63" id="Txm" color="#0B406D" fontWeight="bold" editable="false"/>
                <mx:Label x="40" y="696" text="XML:" fontWeight="bold" fontSize="17"/>
                <mx:HBox x="246" y="608" width="165" height="23" verticalAlign="middle" horizontalGap="5" borderStyle="solid" backgroundColor="#C0BCBC" horizontalAlign="center">
                          <mx:Text text="X:" fontWeight="bold" fontSize="14" color="#151618"/>
                          <mx:Text fontWeight="bold" fontSize="13" id="Xva" width="40" color="#0A239F"/>
                          <mx:Text text="Y:" fontWeight="bold" fontSize="14" color="#151618"/>
                          <mx:Text fontWeight="bold" fontSize="13" id="Yva" width="38" color="#0A239F"/>
                </mx:HBox>
                <mx:Label x="70" y="610" text="Line Thickness:" fontWeight="bold"/>
                <mx:Label x="-1" y="610" text="Color:" fontWeight="bold"/>
      </mx:Application>
      LineTool.as
      package com
                import flash.display.Sprite;
                import flash.events.MouseEvent;
                import mx.core.UIComponent;
                public class LineTool extends UIComponent
                          public var x1:int;
                          public var x2:int;
                          public var y1:int;
                          public var y2:int;
                          public var color:uint;
                          public var thickness:int;
                          public var a:int;
                            public var b:int;
                          private var h1:lineHandle;
                          private var h2:lineHandle;
                          private var shape:Sprite;
                          public function set showHandle(val:Boolean):void
                                    h1.visible=val;
                                    h2.visible=val;
                          public function get showHandle():Boolean
                                    return h1.visible;
                          private function startMove(event:MouseEvent):void
                                    this.startDrag();
                          private function stopMove(event:MouseEvent):void
                                    this.stopDrag();
                          public function LineTool()
                                    super();
                                    width=(x1+x2>8)?x1+x2:8;
                                    height=(y1+y2>8)?y1+y2:8;
                                    h1=new lineHandle();
                                    h1.name="h1";
                                    h1.addEventListener(MouseEvent.MOUSE_DOWN,onMouseDown);
                                    h1.x=x1;
                                    h1.y=y1;
                                      addChild(h1);
                                    h2=new lineHandle();
                                    h2.addEventListener(MouseEvent.MOUSE_DOWN,onMouseDown);
                                    h2.x=x2;
                                    h2.y=y2;
                                    h2.name="h2";
                                    addChild(h2);
                                    /* if(h1.x<h2.x)
                                              x1=h1.x+h1.width/2;
                                              x2=h2.x;
                                    else
                                              x1=h1.x;
                                              x2=h2.x+h2.width/2;
                                    x1=h1.x+h1.width/2;
                                    x2=h2.x+h2.width/2;
                                    y1=h1.y+h1.height/2;
                                    y2=h2.y+h2.height/2;
                                    drawLine1(x1,y1,x2,y2,color,thickness);
                                    showHandle=false;
                           override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                                    super.updateDisplayList(unscaledWidth,unscaledHeight);
                                    h1.x=x1;
                                    h1.y=y1;
                                    h2.x=x2;
                                    h2.y=y2;
                                    /* if(h1.x<h2.x)
                                              x1=h1.x+h1.width;
                                              x2=h2.x;
                                    else
                                              x1=h1.x;
                                              x2=h2.x+h2.width;
                                    x1=h1.x+h1.width/2;
                                    x2=h2.x+h2.width/2;
                                    drawLine(x1,y1,x2,y2,color,thickness);
                          private function drawLine(x1:int,y1:int,x2:int,y2:int,color:uint,t:int):void
                                    /* if(h1.x<h2.x)
                                              x1=h1.x+h1.width;
                                              x2=h2.x;
                                    else
                                              x1=h1.x;
                                              x2=h2.x+h2.width;
                                    x1=h1.x+h1.width/2;
                                    x2=h2.x+h2.width/2;
                                    shape.graphics.clear();
                                    shape.graphics.lineStyle(t,color);
                                    shape.graphics.moveTo(x1,y1);
                                    shape.graphics.lineTo(x2,y2);
                          public function update():void
                          private function drawLine1(x1:int,y1:int,x2:int,y2:int,color:uint,t:int):void
                                    shape=new Sprite();
                                    shape.addEventListener(MouseEvent.MOUSE_DOWN,startMove);
                                    shape.addEventListener(MouseEvent.MOUSE_UP,stopMove);
                                     shape.buttonMode=true;
                                    shape.useHandCursor=true;
                                    /* h2.x=x2;
                                    h2.y=y2; */
                                    this.addChildAt(shape,0);
                                    (event.currentTarget as lineHandle).startDrag();
                                    if(event.currentTarget.name=="h1")
                                              h1.addEventListener(MouseEvent.MOUSE_MOVE,onMouseMove);
                                              h1.addEventListener(MouseEvent.MOUSE_UP,onMouseUp);
                                    else
                                              h2.addEventListener(MouseEvent.MOUSE_MOVE,onMouseMove);
                                              h2.addEventListener(MouseEvent.MOUSE_UP,onMouseUp);
                          private function onMouseMove(event:MouseEvent):void
                                    /* if(h1.x<h2.x)
                                              x1=h1.x+h1.width;
                                              x2=h2.x;
                                    else
                                              x1=h1.x;
                                              x2=h2.x+h2.width;
                                    x1=h1.x+h1.width/2;
                                    x2=h2.x+h2.width/2;
                          /* private function onMouseMove1(event:MouseEvent):void
                                    x1=h1.x;
                                    y1=h1.y;
                                    x2=h2.x;
                                    y2=h2.y;
                          private function onMouseUp(event:MouseEvent):void
                                    /* if(h1.x<h2.x)
                                              x1=h1.x+h1.width;
                                              x2=h2.x;
                                    else
                                              x1=h1.x;
                                              x2=h2.x+h2.width;
                                    x1=h1.x+h1.width/2;
                                    x2=h2.x+h2.width/2;
                                    (event.currentTarget as lineHandle).stopDrag();
                                              h1.removeEventListener(MouseEvent.MOUSE_MOVE,onMouseMove);
                                              h1.removeEventListener(MouseEvent.MOUSE_UP,onMouseUp);
                                    else
                                              h2.removeEventListener(MouseEvent.MOUSE_MOVE,onMouseMove);
                                              h2.removeEventListener(MouseEvent.MOUSE_UP,onMouseUp);
                          public function getLine():XML
                                    var result:XML=new XML(<root/>);
                                    result.line.@x1=uint(x);
                                    result.line.@x2=uint(x2);
                                    result.line.@y1=uint(y);
                                    result.line.@y2=uint(y2);
                                    result.line.@fx=x;
                                    result.line.@fy=y;
                                    result.line.@id=this.id;
                                    result.line.@style="stroke:#"+color+";"+"stroke-width:"+thickness;
                                    //trace("result:"+result.toString());
                                    return result;
      lineHandle.mxml
      <mx:Button buttonMode="true" useHandCursor="true" toolTip="Drag to resize Line" xmlns:mx="http://www.adobe.com/2006/mxml" borderColor="#363636" cornerRadius="0" width="8" height="8">
      </mx:Button>
      OutPut
