3 Replies Latest reply on Nov 11, 2011 5:00 PM by kglad
    Activate & Deactivate Functions!
    McbainGames11 Level 2
      Hey,
      Class 'Main' is my document class:
      Well i have falling objects and i have 2 functions to activating and deactivating which isn't going so well.
      My deactivate function doesn't work very well with resetting everything back to normal.
      Things my deactive function doesn't do:
      -When i call my deactivate function it only pauses the object and when i activate again it will un-pause. << I think this is because i havn't reset my arrays and has them stored for next time.
      Simply, what i want to do is to do the opposite in my class to make the class 'Stop Running'
      So how do i reset my arrays and anything else that needs resetting to deactivate my class,Here is my code , just look for my deactivate function near the top of the code:
      package
          import flash.display.MovieClip;
          import flash.events.Event;
          import flash.events.MouseEvent;
          import flash.events.TimerEvent;
          import flash.utils.Timer;
          import flash.display.DisplayObject;
          public class Main extends MovieClip
              public var enemyA:Array = [];
              public var birdA:Array = [];
              public var MAX_ENEMIES:int = 10;
              public var gap:int = 100;
              public var timer:int = 0;
              public var time_limit:int = 10;
              public var TimerSpeed:uint = 1000;
              public var MyTimer:Timer = new Timer(TimerSpeed);
              public var TheBird:BirdChar = new BirdChar();
              public function Main()
                  // Constructor Code
              public function activateGameControls()
                  createEnemyF();
                  createBirdF();
                  this.addEventListener(Event.ENTER_FRAME,loopF);
                  MyTimer.addEventListener(TimerEvent.TIMER,TimerHandler);
                  MyTimer.start();
              public function deactivateGameControls()
                  if (getChildByName("enemy_mc")!=null)
                  removeChild(getChildByName("enemy_mc"));
                  addChild(TheBird);
                  removeChild(TheBird);
                  this.removeEventListener(Event.ENTER_FRAME, loopF);
                  MyTimer.removeEventListener(TimerEvent.TIMER, TimerHandler);
              public function createEnemyF()
                  for (var i:int = 0; i < MAX_ENEMIES; i++)
                      var enemy:DisplayObject = new Enemy();
                      enemy.x = Math.random() * stage.stageWidth - enemy.width;
                      enemy.y =  -  i * (gap + enemy.height) - 30.65;
                      addChild(enemy);
                      //trace(enemy.x, enemy.y);
                      enemyA.push(enemy);
                      enemy.name = "enemy_mc";
              public function createBirdF()
                  TheBird.x = 270.95;
                  TheBird.y = 350.95;
                  birdA.push(TheBird);
                  addChild(TheBird);
              public function loopF(event:Event)
                  updateBirdPositionsF();
                  updateEnemyPositionsF();
              public function updateEnemyPositionsF()
                  for (var i:int = 0; i < enemyA.length; i++)
                      var enemy:DisplayObject = enemyA[i] as DisplayObject;
                      //trace("this is your enemy #" + i + ": " + enemy + ", do whatever with him.");
                      enemy.y +=  2;
                      if (enemy.hitTestObject(TheBird))
                          //trace("BAAAM! Enemy #" + i + " hit whatever he was supposed to hit.");
                          gotoAndPlay(5);
                          MyTimer.removeEventListener(TimerEvent.TIMER,TimerHandler);
                          deactivateGameControls();
                          addChild(enemy);
                          removeChild(enemy);
              public function updateBirdPositionsF()
                  TheBird.x = mouseX;
              function TimerHandler(event:TimerEvent)
                  timer +=  1;
                  if ((timer == time_limit))
                      gotoAndPlay(5);
                      trace('This level has been completed!');
      Cheers!
