1 Reply Latest reply on Nov 10, 2011 9:53 AM by Flex harUI
    Spark datagrid - ending editing session
    Zolotoj Level 3
      When I start an editing session I am collecting item editors in the following way:
      //  code in datagrid class.
      public function startRowEditing(index:int):void{
                  if(index == editedRowIndex){
                      return;
                  if(dataProvider && dataProvider.length >= index){
                      editedRowIndex = index;
                      // Start moving thru data columns from right to left to end up with the first column going into editing
                      for(var i:int = columns.length - 2; i >= 0; i --){
                          var column:GridColumn = columns.getItemAt(i) as GridColumn;
                          if(column.editable && column.itemEditor){
                              startItemEditorSession(index, i);
                              var editor:DataGridEditor = this.mx_internal::editor;
                              editors.addItem(editor);
      then when the user wants to end editing I running this:
      public function endRowEditing(index:int, cancel:Boolean = false):void{
                  if(editedRowIndex != index){
                      return;
                  for each(var editor:DataGridEditor in editors){
                      editor.endItemEditorSession(cancel);
                  editors.removeAll();
      while ever all it works I do have at least one strange effect. If I click on a cell to enter data then when I end session its item editor disappears,
      but if I tab into a cell, then after ending the session the item editor is still there.
      Any idea, please?
