1 Reply Latest reply: Nov 10, 2011 11:14 AM by Code Girl RSS
    Single Column component with dropdownlist itemeditor
    Michelle5002 Community Member
      Is there something other than a datagrid which can use a combo box as an item editor?
      The reason I ask is because I am currently trying to use a datagrid to display a single column which represents the entire object for the list. so when I select from the dropdownlist the selected object is automatically updated to the list itself.  However, this is not working because the Datagridcolumn is looking for a reference to the dataField you specify and it does not let you specify "this" to refer to the object itself because it seems to be looking for a variable property inside class B rather than being able to reference B itself.  I really do not care which component I use.  I do want a title to the column and the item editor to be a dropdown type list.  Any help would be appreciated.
      For example
      The dataprovidor is a list of Class B inside Class A
      Class A
      List<Class B>
      Class B
      int id
      String name
      The dropdownlist is a list of all Class B's
      valueObject:A a
      valueObject:B b
      DataGrid
                dataProvider="{a.bs}"
                editable="true"
           Column
                DataColumn dataField
                                    dataField="b"     -- this fails    if I put name it only passes name and not the object b
                                    labelFunction="b.name"
                                    editable="true"
                                    editorDataField="value"
                     itemEditor
                          Script
                               function get value:B
                                    return b
                          Declaration
                               valueObject:B id b
                          DropDownList
                               prompt="b.name"
                               dataProvider="bList"
                               labelField="name"
