8 Replies Latest reply on Nov 11, 2011 3:49 AM by jfb00
    Combine two arrays
    jfb00 Level 3
      i got this link from Alex about merging two list
      http://blogs.adobe.com/aharui/2008/03/custom_ilists_checkboxdatagrid_1.html
      I got to the point of this line:
      // merge the two arrays
      mergedIList = new MergedIList(arrayCollection1, arrayCollection2);
      I don't understand the next line:
      // set the function that merges the two arrays into a new extended ValueObject
      mergedIList.factoryFunction = mergeFunction;
      Both of my AC's have a combination of columns the same that I want to check and if they are the same i would like to combine in one AC.
      Anybody here can help me to learn about iList.??
      Thanks!
        • 1. Re: Combine two arrays
          Flex harUI Adobe Employee
          I’m not quite sure what you are looking for so maybe show 3 data objects of each list and what you want the result list to look like
          • 2. Re: Combine two arrays
            jfb00 Level 3
            Hi Alex,
            Here are the two arrayCollections where the common columns are Key01_id and key02_id:
            [Bindable] private var acSample01:ArrayCollection = new ArrayCollection([
                            {key01_id:100, key02_id:120, Fname: "Kranthi", Lname:"Kata"},
                            {key01_id:101, key02_id:121, Fname: "Vasanth", Lname:"Lola"}
            [Bindable] private var acSample02:ArrayCollection = new ArrayCollection([
                             {key01_id:100, key02_id:120, dob:"21/10/1972", Amount:10000, Rate:20},
                             {key01_id:101, key02_id:121, dob:"1/9/1971", Amount:3000, Rate:10}
            How can I combine this two in another array collection like:
            [Bindable] private var acSample:ArrayCollection = new ArrayCollection([
                             {key01_id:100, key02_id:120, Fname: "Kranthi", Lname:"Kata", dob:"21/10/1972", Amount:10000, Rate:20},
                             {key01_id:101, key02_id:121, Fname: "Vasanth", Lname:"Lola", dob:"1/9/1971", Amount:3000, Rate:10}
            In your example I can see the two arrays inside the Ilist but not the combination.
            • 3. Re: Combine two arrays
              Is your goal to also filter out items for which there aren’t matches in the key fields?
              • 4. Re: Combine two arrays
                jfb00 Level 3
                Not now, all records in both arrays match the primary keys.
                Thanks!
                • 5. Re: Combine two arrays
                  The merged function would look like:
                  Private function mergeFunction(obj1:Object, obj2:Object):*
                      var newObject:Object = {};
                      newObject.key01_id = obj1.key01_id;
                      newObject.key02_id = obj1.key02_id;
                      newObject.FName = obj1.FName;
                      newObject.LName = obj1.LName;
                      newObject.dob = obj2.dob;
                      newObject.Amount = obj2.Amount;
                      newObject.Rate = obj2.Rate;
                      return newObject;
                  You may have to switch obj1 and obj2 depending on your setup.
                  • 6. Re: Combine two arrays
                    jfb00 Level 3
                    Nice Alex,
                    I am going to try to build this object dynamically since i have so many columns.
                    Thanks!
                    • 7. Re: Combine two arrays
                      To build dynamically, you can use for..in loops.  I would recommend writing a data class to hold the merged data.  Property access will be slightly faster and the compiler and runtime will find mistakes.
                          var newObject:MergedDataClass = new MergedDataClass();
                          for (var p:String in obj1)
                              newObject[p] = obj1[p];
                          for (var p:String in obj2)
                              newObject[p] = obj2[p];
                          return newObject;
                      • 8. Re: Combine two arrays
                        jfb00 Level 3
                        Excellent Alex,
                        Thanks for your help!
                        Best
