0 Replies Latest reply on Nov 10, 2011 7:06 AM by ealysse1
    New to Flex - Issue with swatches & fillColor
    ealysse1 Level 1
      Hi Everyone,
      I'm new to scripting in Adobe, though I have experience with Java.  Quick background - I'm running trial versions of both Flash Builder and Creative Suite Extension Builder to test them out prior to purchase.  My problem is with using swatches and fillColor.  From what I've found, it seems like these should not have any problem since I am importing com.adobe.illustrator.*, but my scripts throw errors.  I have two examples of code below and both seem to have the same issue whether I'm trying to access defaultFillColor or fillColor- Attempted access of inaccessible method through a reference with static type com.adobe.illustrator...  The first script I haven't gotten to work yet.  The second script works, but doesn't fill the triangle.  Any insight would be greatly appreciated.  Thanks in advance!
      Script 1:
          import com.adobe.csawlib.illustrator.Illustrator;
          import com.adobe.csxs.core.csxs_internal;
          import com.adobe.illustrator.*;
          public class testOne
              private static var app:Application = Illustrator.app;
              public function functionTestOne()
                  // add a layer
                  app.activeDocument.layers.add();
                  var InfoLayer = Illustrator.app.activeDocument.activeLayer.name("Info Layer");
                  // create a rectangle using swatch to fill
                  Illustrator.app.activeDocument.defaultFillColor("Fusion");
                  var rectOne = colorInfoLayer.pathItems.rectangle( 72, 72, 72, 72 );
      Script 2:
          public class testTwo
              public function createDocument():void
                  var application:Application = Illustrator.app;
                  var document:Document = application.documents.add();
                  var trianglePath:PathItem = document.pathItems.add();
                  trianglePath.setEntirePath(new Array(new Array(100, 100), new Array(300, 100), new Array(200, Math.tan(1.0471975) * 100 + 100) ) );
                  trianglePath.closed = true;
                  trianglePath.stroked = true;
                  trianglePath.filled = true;
                  trianglePath.strokeWidth = 3;
                  document.pathItems[0].fillColor = document.swatches.getByName("White").color;
                  var model:AppModel = AppModel.getInstance();
