4 Replies Latest reply on Nov 10, 2011 10:11 AM by Kardii
    Blurring paint strokes
    Kardii
      Hi there,
      does anyone know of any way to blur a paint stroke in AE CS5? I have cloned a few things on some footage and I would like to soften the edge a bit on certain areas of the paint strokes. I'm use to combustion where you could achieve this really easy by changing your brush to a blur brush and just painting it. Being an adobe product I assume there is some solution for this? It would also be nice to have access to other effects such as smudge and what not.
      thanks in advanced,
      Kardii
        • 1. Re: Blurring paint strokes
          There is no "other effects" for brush strokes. AE's brush is really just limited to cloning, painting and Rotobrush. Everything else must be done using per-layer effects. In your case you could simply use a soft brush or use a duplicate of your paint stuff, then blur it and apply it as a track matte to the actual clone brush strokes.
          Mylenium
          • 2. Re: Blurring paint strokes
            Kardii Level 1
            Thanks for the quick reply. I've tried using the softest brush possible but since I'm painting with such a small brush size it still comes off as a fairly hard edge. In regards to the duplicating/track matte solution, it seems like a lot of extra work just so I can add a little blur to some of the edges. I usually comp around 50 shots or so a week and doing these little work arounds adds up, I guess I have to tough it out. Most things AE seems to do really well, theres just the odd instance like this where it drives me crazy.
            Kardii
            • 3. Re: Blurring paint strokes
              There's some functionality you'd like to see added? Go here! The more they get, the more likely they'll be to implement it.
              • 4. Re: Blurring paint strokes
                Kardii Level 1
                Ahh perfect! thanks for the link!
