3 Replies Latest reply on Nov 11, 2011 2:39 AM by Brezhnev29
    Flex Mobile: Access parent view variable within itemrenderer component
    VivD
      I have multiple images in a list and I want to display 4 of them at a time on the screen with in a tiled layout with each image's width= 50% of screen width and height = 50% screen height.
      I have been able to do that with the code below.
      <s:List id="list1" width="100%" height="100%">
                          <s:ArrayCollection>
                                    <fx:Object id="img1" img_url="assets/1-1.png" title="Image 1"/>
                                    <fx:Object id="img2" img_url="assets/1-2.png" title="Image 2"/>
                                    <fx:Object id="img3" img_url="assets/2-1.png" title="Image 3"/>
                                    <fx:Object id="img4" img_url="assets/2-2.png" title="Image 4"/>
                          </s:ArrayCollection>
                          <s:layout>
                                    <s:TileLayout
        columnAlign="justifyUsingWidth" horizontalAlign="center" verticalAlign="middle"
        paddingBottom="0" paddingLeft="0" paddingRight="0" paddingTop="0"
        horizontalGap="0" verticalGap="0"
                          </s:layout>
                          <s:itemRenderer>
                                    <fx:Component>
                                              <s:ItemRenderer>
                                                        <s:Group width="160" height="240">
        <s:BitmapImage source="{data.img_url}" scaleMode="stretch" smooth="true"
        width="100%" height="100%"/>
        <s:Label text="{data.title}" left="0" bottom="0" width="100%" />
                                                        </s:Group>
                                              </s:ItemRenderer>
                                    </fx:Component>
                          </s:itemRenderer>
                </s:List>
      However, I don't want to hard code the width and height values.
      I am able to obtain the accurate screen height and width in the viewAcivate event of the View as shown below.
      protected function view1_viewActivateHandler(event:ViewNavigatorEvent):void
                                              ScreenWidth = screen.width;
                                              ScreenHeight = screen.height;
      How do I apply those values to the Group width/height properties in the itemrenderer?
      Something like...
      <s:ItemRenderer>
                                                        <s:Group width="{ScreenWidth/2}" height="{ScreenHeight/2}">
                                                        </s:Group>
                                              </s:ItemRenderer>
        • 2. Re: Flex Mobile: Access parent view variable within itemrenderer component
          VivD Level 1
          Thanks. That worked.
          One additional question. In my code above I keep getting the following warning. Not able to find out how to get rid of it.
          warning: unable to bind to property 'img_url' on class 'Object' (class is not an IEventDispatcher)
          warning: unable to bind to property 'title' on class 'Object' (class is not an IEventDispatcher)
          • 3. Re: Flex Mobile: Access parent view variable within itemrenderer component
            Brezhnev29
            Hi VivD,
            Use this method, remove the warning message.
                                <s:ArrayCollection>
                                <s:layout>
                                          <s:TileLayout
                                </s:layout>
                                <s:itemRenderer>
                                          <fx:Component>
                                                    <s:ItemRenderer>
                                               <fx:Script>
                                                    <![CDATA[
                                                         override public function set data(value:Object):void {
                                                          lbl.text = value.title; img.source= value.img_url;
                                                </fx:Script>
        <s:BitmapImage id="img" scaleMode="stretch" smooth="true"
        <s:Label  id="lbl" left="0" bottom="0" width="100%" />
                                                              </s:Group>
                                                    </s:ItemRenderer>
                                          </fx:Component>
                                </s:itemRenderer>
                      </s:List>
