4 Replies Latest reply on Nov 16, 2011 6:51 AM by jomor21
    Passing variable value and used it as component name?
    jomor21
      From a button a call to a function
      private function addContent(compon:String):void {
      Then I put in the code =
      var content:mycomponente = new components.mycomponete;
      Everything works fine.
      But I want to put the value of the variable loaded in the function (compon), as the name of the “component” .
      I tested  this code:
      var content:"${comp}"= new components.["${ compon}"];
      And it does not work. I've tested lots of combinations and nothing.
        • 1. Re: Passing variable value and used it as component name?
          Flex harUI Adobe Employee
          You can’t parameterize a compile-time type.  You can use a general type.
              var content:Object (or some other base class or interface for all types involved)
          You can convert a string to a type at runtime via getDefinitionByName, but you need a fully qualified class name.
          • 2. Re: Passing variable value and used it as component name?
            jomor21 Level 1
            I have tried what you tell me with all these variables:
            Var myClass: UIComponent, Object, Class, ComponentDescriptor
            and not get it to work
            I use a ViewStack with 6 canvas, activated by 6 buttons,  they call to a different external component type panel.
            If I can use as a reference parameter I can use a single function (with remove and add element) otherwise need to use 6 function.
            Flex harUI Thank you for your answer
            From Barcelona.
            • 3. Re: Passing variable value and used it as component name?
              Lisa_Florian
              Is this what you look for?
              viewStack.selectedChild = getChildByName(compon);
              • 4. Re: Passing variable value and used it as component name?
                jomor21 Level 1
                Nothing, not getting to work
                This is my code
                    if (compon == "tfg_compColeccion"){
                          var content:tfg_compColeccion = new components.tfg_compColeccion;
                          content.addEventListener("removeMe",onRemove,false,0,true);
                          var navContent:Canvas = new Canvas();
                          navContent.id = 'coleccion';
                          navContent.label = 'coleccion';
                          navContent.width = Number('100%');
                          navContent.height = Number('100%');
                          navContent.addElement(content);
                          myViewStack.addElement(navContent);
                          myViewStack.selectedChild = navContent;
                   private function onRemove(event:Event):void
                    var content:NewContent = event.currentTarget as NewContent;
                    content.removeEventListener("removeMe",onRemove,false);
                    myViewStack.removeChild(content.parent.parent.parent);
                thank you very much
