3 Replies Latest reply on Nov 12, 2011 6:16 AM by Zolotoj
    Spark DG editing session
    Zolotoj Level 3
      Let's say I have two columns. ONe with a textArea as an item Editor and another with a dropdown.
      I am starting an editing session programmatically in all columns at once and I see a dropdown and a border around a textArea.
      If I click outside of the grid the textArea disappears, but the dropdown stays there.
      In general, is it wrong, and if yes, what a reason might be?
        • 1. Re: Spark DG editing session
          Flex harUI Adobe Employee
          I don’t think we support two editors at once, so you’re pretty much on your own here.
          • 2. Re: Spark DG editing session
            Zolotoj Level 3
            Ok, I see. Wasn't my idea in a first place. But, I am also noticing that even with the textArea when I click outside of the grid the editing is not going away - the control still has black but thicker border and clicking back allows continuing editing.
            • 3. Re: Spark DG editing session
              Zolotoj Level 3
              Yes, I realize that, but I took over a project where that was a requirement. Now, I am trying to build a small test case to post it here and ask questions I have, but I cannot replicate this multi editor crap.
              Somehow the original developer could  create editors in multiple columns at the same time. I am hoping someone will give at least an idea how to make it work. Here it goes:
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             width="450" xmlns:local="*"
                              creationComplete="myDG.startEditing(0)">
                  <s:layout>
                      <s:VerticalLayout/>
                  </s:layout>
                  <fx:Script>
                      <![CDATA[
                          import mx.collections.ArrayCollection;
                          import mx.collections.IList;
                          import mx.core.IFactory;
                          import mx.events.ListEvent;
                          use namespace mx_internal;
                          import spark.components.gridClasses.DataGridEditor;
                          protected var editors:IList = new ArrayCollection();
                          [Bindable]
                          private var myDP:ArrayCollection = new ArrayCollection([
                              {label1:1, quant:3, color:'red'},
                              {label1:2, quant:3, color:'green'}
                          public function onChange(index:int):void
                              for(var i:int = 0; i < myDG.columns.length - 2; i ++){
                                  var column:GridColumn = myDG.columns.getItemAt(i) as GridColumn;
                                  if(column.editable && column.itemEditor){
                                      myDG.startItemEditorSession(index, i);
                                      var editor:DataGridEditor = myDG.mx_internal::editor;
                                      editors.addItem(editor);
                  </fx:Script>
                  <local:testGrid id="myDG" width="100%"
                              dataProvider="{myDP}"
                      <local:columns>
                          <s:ArrayCollection>
                              <s:GridColumn dataField="label1" headerText="Order #" editable="true">
                                  <s:itemEditor>
                                      <fx:Component>
                                          <local:TextInputRenderer/>
                                      </fx:Component>
                                  </s:itemEditor>
                              </s:GridColumn>
                              <s:GridColumn dataField="quant" headerText="Qty" editable="true">
                                  <s:itemEditor>
                                      <fx:Component>
                                      </fx:Component>
                                  </s:itemEditor>
                              </s:GridColumn>
                              <s:GridColumn dataField="color" headerText="Color" editable="true" >
                                  <s:itemEditor>
                                      <fx:Component>
                                          <local:DropDownItemRenderer/>
                                      </fx:Component>
                                  </s:itemEditor>
                              </s:GridColumn>
                              <s:GridColumn headerText="1234" editable="false">
                                  <s:itemRenderer>
                                      <fx:Component>
                                          <s:GridItemRenderer>
                                              <s:Button/>
                                          </s:GridItemRenderer>
                                      </fx:Component>
                                  </s:itemRenderer>
                              </s:GridColumn>
                          </s:ArrayCollection>
                      </local:columns>
                  </local:testGrid>
                  <s:Button />
              </s:Application>
              // testGrid
              package
                  import mx.core.mx_internal;
                  import spark.components.DataGrid;
                  import spark.components.gridClasses.GridColumn;
                  [Bindable]
                  public class testGrid extends DataGrid
                      public function testGrid()
                          super();
                          selectionMode="none";
                          editable = true;
                      private var _data:Object;
                      public function get data():Object{
                          return _data;
                      public function set data(val:Object):void{
                          _data = val;
                      override public function startItemEditorSession(rowIndex:int, columnIndex:int):Boolean
                          this.mx_internal::editor = this.mx_internal::createEditor();
                          return this.editor.startItemEditorSession(rowIndex, columnIndex);
                      public function startEditing(index:int):void
                          for(var i:int = 0; i < columns.length - 2; i ++){
                              var column:GridColumn = columns.getItemAt(i) as GridColumn;
                                  var editor:DataGridEditor = mx_internal::editor;
              // TextInputRenderer
              ADOBE SYSTEMS INCORPORATED
              Copyright 2010 Adobe Systems Incorporated
              All Rights Reserved.
              NOTICE: Adobe permits you to use, modify, and distribute this file
              in accordance with the terms of the license agreement accompanying it.
              <!--- The DefaultGridItemEditor class defines the default item renderer used
              by the Spark grid controls, such as DataGrid and Grid.
              The DefaultGridItemEditor  displays a text area control.
              Enter the new value for the cell in the text editor.
              <p>Instead of using the DefaultGridItemEditor, you can create
              a custom item editor. The item editor must implement the
              spark.components.gridClasses.IGridItemEditor interface.
              Typically, you create an item editor as a subclass of the
              spark.components.gridClasses.GridItemEditor class.</p>
              @see spark.components.DataGrid
              @see spark.components.Grid
              @see spark.components.gridClasses.IGridItemEditor
              @see spark.components.gridClasses.GridItemEditor
              @see spark.components.gridClasses.GridColumn
              @langversion 3.0
              @playerversion Flash 10
              @playerversion AIR 2.5
              @productversion Flex 4.5
              <s:GridItemEditor xmlns:fx="http://ns.adobe.com/mxml/2009"
                                xmlns:gridEditorClasses="spark.components.gridEditorClasses.*"
                                width="100%" xmlns:ns="library://commons.stoneriver.com"
                  <fx:Script>
                      <![CDATA[
                          import mx.core.IUITextField;
                          import mx.core.IVisualElement;
                          import mx.events.ResizeEvent;
                          import spark.components.gridClasses.IGridItemRenderer;
                          import spark.core.IEditableText;
                          import spark.primitives.Rect;
                          //  Overridden properties
                           *  @private
                          override public function get value():Object
                              return textArea.text;
                           *  @private
                          override public function set value(newValue:Object):void
                              textArea.text = newValue != null ? newValue.toString() : "";
                          //  Overidden methods
                           *  @private
                           *  @private
                          override public function setFocus():void
                              textArea.setFocus();
                  </fx:Script>
                  <!--- The editor's TextArea component.
                  @langversion 3.0
                  <s:TextArea id="textArea" horizontalScrollPolicy="off" verticalScrollPolicy="off" width="100%"/>
              </s:GridItemEditor>
              //DropDownItemRenderer
              <!--- The ComboBoxGridItemEditor class defines an item renderer for use
              with the Spark grid controls, such as DataGrid and Grid.
              The ComboBoxGridItemEditor  displays a drop-down list of cell values.
              Select a value to set the new value of the cell.
              <p>The following example shows a GridColumn using the ComboBoxGridItemEditor
              as its item editor:</p>
              <pre>
              &lt;s:GridColumn dataField="quant"
              headerText="Qty"&gt;
              &lt;s:itemEditor&gt;
              &lt;fx:Component&gt;
              &lt;s:ComboBoxGridItemEditor&gt;
              &lt;s:dataProvider&gt;
              &lt;s:ArrayList&gt;
              &lt;fx:int&gt;0&lt;/fx:int&gt;
              &lt;fx:int&gt;1&lt;/fx:int&gt;
              &lt;fx:int&gt;2&lt;/fx:int&gt;
              &lt;fx:int&gt;3&lt;/fx:int&gt;
              &lt;/s:ArrayList&gt;
              &lt;/s:dataProvider&gt;
              &lt;/s:ComboBoxGridItemEditor&gt;
              &lt;/fx:Component&gt;
              &lt;/s:itemEditor&gt;
              &lt;/s:GridColumn&gt;
              </pre>
              @langversion 3.0
                                xmlns:gridEditorClasses="spark.components.gridEditorClasses.*">
                  <fx:Script>
                      <![CDATA[
                          import mx.collections.ArrayList;
                          import spark.events.DropDownEvent;
                          [Bindable]
                          private var myDP:ArrayList = new ArrayList(["red", "green", "blue"]);
                          //  Overriden properties
                           *  @private
                           *  returns the selected value in the comboBox.
                              if (comboBox.selectedItem)
                                  return comboBox.selectedItem;
                              else
                                  return null;
                           *  @private
                           *  Set the selected item of the combo box with the data from the
                           *  item.
                              comboBox.selectedItem = newValue;
                          //  Properties
                          //  dataProvider
                          private var _dataProvider:IList;
                          [Bindable("comboBoxGridItemEditorDataProviderChanged")]
                           *  The data provider for the combox box in the item editor.
                           *  @langversion 3.0
                           *  @playerversion Flash 10
                           *  @playerversion AIR 2.5
                           *  @productversion Flex 4.5
                          public function get dataProvider():IList
                              return _dataProvider;
                           *  @private
                          public function set dataProvider(value:IList):void
                              if (_dataProvider == value)
                                  return;
                              _dataProvider = value;
                              dispatchEvent(new Event("comboBoxGridItemEditorDataProviderChanged"));
                          //  Overridden methods
                           *  @private
                          override public function prepare():void{
                              super.prepare();
                           *  @private
                              // delegate focus to the combox box.
                              comboBox.setFocus();
                           *  @private
                          private function dropDown_openHandler(event:DropDownEvent):void
                              // Add a mouse down handler for the dropDown part. When
                              // the user clicks in the drop down we want to end the editing
                              // session. We listen to the dataGroup here instead of the dropDown
                              // part to avoid closing the editor when the dropDown's
                              // scrollbar is clicked.
                              if (comboBox.dataGroup)
                                  comboBox.dataGroup.addEventListener(MouseEvent.MOUSE_DOWN, dataGroup_mouseClickHandler, false, 0, true);
                           *  @private
                          private function dataGroup_mouseClickHandler(event:MouseEvent):void
                              // When the drop down list is clicked, end the editting session
                              // to allow the edit to be completed with just one click.
                              // Use callLater to let the click and change handlers finish
                              // before we close the editor.
                              callLater(dataGrid.endItemEditorSession);
                  </fx:Script>
                  <!--- @private
                  Background to cover the cell that the ComboBox control does not.
                  @langversion 3.0
                  <!--- The item editor's ComboBox control.
                  @langversion 3.0
                  <s:DropDownList id="comboBox" width="100%" dataProvider="{myDP}" labelField="color"
              </s:GridItemEditor>
              When I run it I am getting an error:
              TypeError: Error #1009: Cannot access a property or method of a null object reference.
                  at spark.components.gridClasses::DataGridEditor/setEditedItemPosition()[E:\dev\4.5.1\framewo rks\projects\spark\src\spark\components\gridClasses\DataGridEditor.as:312]
                  at spark.components.gridClasses::DataGridEditor/dataGrid_gridItemEditorSessionStartingHandle r()[E:\dev\4.5.1\frameworks\projects\spark\src\spark\components\gridClasses\DataGridEditor .as:1204]
                  at flash.events::EventDispatcher/dispatchEventFunction()
                  at flash.events::EventDispatcher/dispatchEvent()
                  at mx.core::UIComponent/dispatchEvent()[E:\dev\4.5.1\frameworks\projects\framework\src\mx\co re\UIComponent.as:13128]
                  at spark.components.gridClasses::DataGridEditor/startItemEditorSession()[E:\dev\4.5.1\framew orks\projects\spark\src\spark\components\gridClasses\DataGridEditor.as:798]
                  at testGrid/startItemEditorSession()[C:\testarea\Flex\Test Project\gridComboRenderer\src\testGrid.as:34]
                  at testGrid/startEditing()[C:\testarea\Flex\Test Project\gridComboRenderer\src\testGrid.as:41]
                  at gridComboRenderer/___gridComboRenderer_Application1_creationComplete()[C:\testarea\Flex\T est Project\gridComboRenderer\src\gridComboRenderer.mxml:6]
                  at mx.core::UIComponent/set initialized()[E:\dev\4.5.1\frameworks\projects\framework\src\mx\core\UIComponent.as:1818]
                  at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.5.1\frameworks\projects\frame work\src\mx\managers\LayoutManager.as:842]
                  at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.5.1\frameworks\projec ts\framework\src\mx\managers\LayoutManager.as:1180]
              here is a line with error:
              dataGridEvent.columnIndex = editedItemPosition.columnIndex;
              and editedItemPosition is null.
              Thanks for any help.
