1. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Bob Levine Nov 13, 2011 5:50 AM (in response to Automator21)Do any of your web overlays point to a URL that redirects to another? If so, you need to use the destination URL.
Bob
2. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Johannes Eckert Nov 13, 2011 5:54 AM (in response to Automator21)This might be a strange bug that occurs here and there ... what is the URL you are pointing to?
AFAIK the bundler/content generator/folio builder is not aware of the content of the URL at the moment of upload, Bob.
This more sounds like a malformed URL.
—Johannes
3. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Bob Levine Nov 13, 2011 5:59 AM (in response to Johannes Eckert)Could be…I’m working by email and not checking for screenshots and other visual references.
I do believe the URL has to have the http:// in it and I’ve seen problems when folks leave that out.
For local HTML content make sure there are no spaces in file names.
Bob
4. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Automator21 Nov 13, 2011 9:02 AM (in response to Automator21)Thank for the replys... That the issue, Im not pointing to any URL's that are redirecting. See my test page, if i remove the Object States at the bottom and delete the "TNP" logo the file uploads fine. I'm certain this might be a bug because it is only happening here and there just like Johannes thinks, everything was working perfect just right before I updated the folio panel. Any other troubleshooting ideas I should try?
5. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Bob Levine Nov 13, 2011 9:10 AM (in response to Automator21)Object states? Did you name the states or the MSO? If so, stick to alphanumeric characters only. Avoid characters like ampersands.
Bob
6. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Automator21 Nov 13, 2011 9:36 AM (in response to Automator21) -
7. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Tomek Kuczborski Nov 13, 2011 9:45 AM (in response to Automator21)I had this problem several versions ago. Some other people reported it as well. In my case, recreating (not copying from other file!) the problem page in InDesign file helped.
Tomek
8. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Automator21 Nov 13, 2011 2:06 PM (in response to Automator21)I recreated the pages on a new indesign file instead of copying and tried again to upload my folio and to my surprise it work like a charm. Thanks Tomek!!! Adobe needs to see if this indeed is a bug or what might be cauing this, thanks for everyone's input.
9. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Tomek Kuczborski Nov 13, 2011 2:22 PM (in response to Automator21)I think it's not a straightforward bug.
It might be some obscure (hidden) absolute path info from the source file, messing up things in exported destination file.
Good you're up and rolling again!
10. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
mobly Nov 14, 2011 12:21 AM (in response to Automator21)I'm pretty sure I know what the problem is, I've posted about this before.
The problem (in may case) seems that if you create a box and then create a webview of it and add a URL, but then subsequently
remove the url and leave it blank, then perhaps use it for another image that isn't a web view, then the system still thinks that that the image box is still a webview and generates an error.
So the moral here is, double check that any image boxes that you may have checked as webview, are being used as such, and have a valid url, any that are not being used, and have blank url fields are still "live" and throw up errors.
cheers
Alistair
11. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
Bob Levine Nov 14, 2011 5:46 AM (in response to mobly)That’s a really good tip.
Simply deleting the URL from the field doesn’t change the fact that you have it set as a web content overlay.
Bob
12. Re: Invalid URL for Web Content Overlay, ERROR!!!!!!
SJKrup Jul 12, 2012 1:31 PM (in response to Tomek Kuczborski)I was having the same problem with both hyperlinks and buttons in one particular file -- "Invalid URL for Web Content Overlay." It seems to only be a problem in files where I had a link or button previously, and then deleted the object. When I create a new object and create a link or button, it's as though the old link is still lingering somewhere in the file! However, none of the old links is listed in the hyperlinks panel before I create a new one.
This occurred while I was teaching a DPS class, using the Adobe courseware (sight unseen by any proofreader, I believe). In one of the exercise files, the steps for the student to create hyperlinks and buttons had already been done, so I deleted the hyperlinks. (I think I deleted the text frames that contained them, but I'm not sure.) I never had a problem with it UNTIL I downloaded the Overlay Creator/Folio Builder dated June 19 (v21, I think).
In the same file, I also had problems with a NAVTO link, . I don't think there were any NAVTO links in any earlier version of the file, at least none that I ever created or deleted.
I've coded HTML since the days when the only available tool was Notepad, so I'm sure that I used correct URLs (and none redirected). Even the URLs in the deleted objects were correct; I only deleted them so the exercise could be done again.
