1 Reply Latest reply on Nov 13, 2011 6:32 AM by kglad
    3D Rotation
    EljahFalling
      I am trying to rotate a symbol about the y-axis, 45 degrees one direction, then back to center, then 45 degrees the other direction.  Seems like a relatively simple task, except here is what happens.
      Here is the object with no rotation:
      Here is the object rotated exactly 45 degrees:
      And here is the object roatated exactly -45 degrees:
      Anyone see a slight inconsistency here??  I need the object to rotate the same as it did the first time but in reverse, otherwise "45" and "-45" are generally worthless numbers to refer to...
      Is it something to do with the pivot point?  I made sure the registration point was in the center when I created the symbol.  It doesn't seem to be pivoting the object around the center though.  How do I rotate about the y-axis using a pivot point that is actually in the center and gives the same (but opposite) effect when rotating it one way versus the other?
        • 1. Re: 3D Rotation
          using actionscript you pivot about the registration point.  in the ide you're pivoting about that 3d-rotation symbol that's on your stage.
          because that symbol is in two different spots with your two rotations, your pivot point is changed.  to remedy, use the same pivot point.
