2 Replies Latest reply on Nov 27, 2011 4:56 PM by Cillas
    Image Size in Graph
    Cillas Level 1
      Hi im trying to build a Graph Image Filter but get stuck.
      for the single kernel it works perfect if i get the image size by
        parameter float2 srcSize
          parameterType: "inputSize";
          inputSizeName: "src";
      tried that too with a graph parameter and metadata, but the single kernels wont get the actual size, how can i do that?
        • 1. Re: Image Size in Graph
          chauffeurdevan Level 2
          I've found that a few months ago, and by the way, it seems the only way to get the sourceSize working in After Effects.
          The glogal graph parameter :
          <parameter type="float2" name="sourceSize" >
              <metadata name="minValue" type="float2" value="1"/>
              <metadata name="maxValue" type="float2" value="4096" />
              <metadata name="defaultValue" type="float2" value="1920., 720." />
              <metadata name="aeUIControl" value="aePoint" />
              <metadata name="aePointRelativeDefaultValue" type="float2" value="1, 1" />
          </parameter>
          In every kernel that you need it :
          parameter float2 sourceSize<
              parameterType : "inputSize";
              inputSizeName : "src";
          You also need to connect it in the node's evaluate parameter :
          <node id = "yourKernel" name ="yourKernel" namespace = "yourNamespace" vendor = "yourVendorName" version ="1">
              <evaluateParameters>
                  <![CDATA[void evaluateParameters() {
                      yourKernel::sourceSize = sourceSize;
              </evaluateParameters>
          </node>
          Voilà
          Jocelyn Tremblay
          • 2. Re: Image Size in Graph
            Cillas Level 1
            wow, i found that out by myself but u answered me another question s great thanks to you.
            After Effects is unable to get the size without these
            so thanks!
