2 Replies Latest reply on Nov 15, 2011 11:14 AM by the_wine_snob
    PNGs from Premiere to PhotoShop
    Joseph_Morabito
      First, I apologize upfront for not knowing the proper nomenclature. I'm hoping this is a basic question for those that know the answer. Since this question deals with both Premiere and PhotoShop, I posted the question in both forums.
      Ok, this is a combo question that involves both Premiere and PhotoShop (cs5). While in Premiere, I'll take a PNG pic of a frame so that I can then rotoscope it. When I open it in PhotoShop, the image is no longer in the 16/9. It is the same height, but the width has been compressed. When I am finished with the file and reimport it to Premiere, it has the wrong look. I can monkey with the image by  unlinking the scale (something like 94% to 140%). That tricks it to be acceptable for my uses, but it would never work for real life images.
      My question is... is there a better setting to choose when taking a frame capture to avoid this? I must be making an elementary mistake that I am unaware of.
      Thanks for your time... hope
        • 1. Re: PNGs from Premiere to PhotoShop
          Harm Millaard Level 7
          Start reading on PAR, pixel aspect ratio. Your source material is probably not using square pixels in PR and PS is interpreting them as square pixels. Hence the distortion.
          • 2. Re: PNGs from Premiere to PhotoShop
            the_wine_snob Level 9
            Along with Harm's comments (sounds like a PAR issue to me too), PS will ONLY display Square Pixels, but should warn you, if the Image is using Non-Square Pixels. PS, as of version CS, can work well with Non-Square Pixels, regardless of how it displays them.
            First, in PrPro, check the Properties of your Video Clip. Determine what the PAR is.
            Then, I would use TIFF, as it handles Non-Square Pixels well. Not all Image formats can deal with Non-Square Pixels.
            After you have done the Export of that Frame, Open it in PS, and again, check the PAR, Image>Pixel Aspect Ratio.
            Edit, as is needed, and then I would Save_As PSD from PS, and Import that into PrPro.
            For some background on PAR (Pixel Aspect Ratio), see this ARTICLE.
            PS - I'll post to your PS Forum thread too, so that others might be helped by the answer.
            [Edit] For display on non-Square Pixels in PS, one can turn OFF Pixel Aspect Ratio Correction under View.
            Message was edited by: Bill Hunt - Added [Edit]
