1 Reply Latest reply on Nov 14, 2011 3:18 PM by flyingj481
    Uploading Captivate 5.5 files into Presenter 7
    Rob_QVC
      I am creating small training modules, 5-10 slides each.  I have created two and imported them into Presenter.  When I go to publish and view what it will look like, the viewer flies through the module and looses all interactivity.  It basically stays in a loop.   As you can see frmo the image the cpativate info button also appears.  I have turned off preloader and autoplay.  What can I do?
        • 1. Re: Uploading Captivate 5.5 files into Presenter 7
          flyingj481 Adobe Community Professional (Moderator)
          What version of Presenter? If you are using Presenter 7.0.6 or earlier, then the issue is that the Captivate SWF is AS3 and Presenter is AS2. If you haven't yet, download Presenter 7.0.7 from Adobe's website and then uninstall Presenter, and reinstall using the current installer. You will need your serial key for Presenter when doing this, so make sure you have it handy.
          Also, as a side note, if you are putting this in Presenter, you may want to consider either hiding or externalizing the playbar in Captivate so you don't confuse viewers with two playbars.
