7 Replies Latest reply on Dec 30, 2011 3:12 PM by failed_spirit
    Adobe X OCR Crashes in Lion
    jayKapp
      Hello,
      I read a similar question about Adobe Acrobat X OCR crashing after 200 pages or so but in my instance it crashes after only three or four pages.
           iMac 2010 with 16GB RAM
           Running OSX 10.7.2 (Lion)
           Adobe Acrobat 10.1.1
      I normally will scan documents into my computer using a Fujitsu scan snap.  It worked fine in Snow Leopard.  I can still scan documents to my iMac in pdf format using Lion but once I apply OCR to the document using Tools, the program crashes if the document is more than three pages long.  I have plenty of RAM (16 GB) and the only difference I can discern is the upgrade to Lion.
      Once the program crashes, it is as if Adobe never processed it.  If I go to open recent files, the program that crashed is not found.  Fortunately, a copy is in my scan holding folder but I have to manually go to it and open it.   This crash occurs every time.
      Does anyone have a similar experience or have found a way to fix this problem.
      Thanks in advance for your advice.
      Jay
        • 1. Re: Adobe X OCR Crashes in Lion
          apangasa Adobe Employee
          Can you please share any test file where you can reproduce the crash?
          • 2. Re: Adobe X OCR Crashes in Lion
            Phillip M Jones Level 4
            Look for Crash reports for Acrobat choose any sections related to times of Crash.
            In fact actaully set out to deliberately crash acrobat using OCR. Then when Crash window appears select everything in the window and do command(⌘)-C then Come to this Thread and do command(⌘)-V to paste in thread.
            • 3. Re: Adobe X OCR Crashes in Lion
              jayKapp Level 1
              This is VERY long but here it is.  This occured after scanning a six page document.
              Process:     AdobeAcrobat [483]
              Path:        /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
              Identifier:  com.adobe.Acrobat.Pro
              Version:     10.1.1 (10.1.1)
              Code Type:   X86 (Native)
              Parent Process:  launchd [201]
              Date/Time:   2011-11-22 20:20:43.952 -0600
              OS Version:  Mac OS X 10.7.2 (11C74)
              Report Version:  9
              Interval Since Last Report:      422063 sec
              Crashes Since Last Report:       10
              Per-App Interval Since Last Report:  387885 sec
              Per-App Crashes Since Last Report:   5
              Anonymous UUID:                  20009136-7C32-424E-A127-8A5789319AD4
              Crashed Thread:  0  Dispatch queue: com.apple.main-thread
              Exception Type:  EXC_BAD_INSTRUCTION (SIGILL)
              Exception Codes: 0x0000000000000001, 0x0000000000000000
              Application Specific Information:
              objc[483]: garbage collection is OFF
              Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
              0   ???                       0x13ebe830 0 + 334227504
              1   ???                       0x13ebe8b4 0 + 334227636
              2   ???                       0x13ebb2e7 0 + 334213863
              3   com.irislink.iDRS14_5     0x0f794317 PreproGetLine(void*, int, unsigned char*) + 64
              4   com.irislink.mac.DRS_iDRS 0x1700ac3d get_line + 31
              5   com.irislink.mac.DRS_iDRS 0x1700b274 sk_color + 334
              6   com.irislink.iDRS14_5     0x0f795c97 idrs_sk_color(int (*)(void*, int, unsigned char*), void*, int, int, int, int*, int*) + 78
              7   com.irislink.iDRS14_5     0x0f7657e5 IDRS::CImgProcessor::Deskew(IDRS::CImage&, int&, int&) + 663
              8   ???                       0x13ebaa3a 0 + 334211642
              9   ???                       0x13ec1073 0 + 334237811
              10  ???                       0x13ef436d 0 + 334447469
              11  com.adobe.AcrobatPlugin.PaperCapture0x0f01c868 AcroPluginMain + 90518
              12  com.adobe.AcrobatPlugin.PaperCapture0x0f01f439 AcroPluginMain + 101735
              13  com.adobe.AcrobatPlugin.PaperCapture0x0f020222 AcroPluginMain + 105296
              14  com.adobe.Acrobat.framework   0x006082a0 AcroSecurityBailOutImpl + 2232720
              15  com.adobe.Acrobat.framework   0x0047f474 AcroSecurityBailOutImpl + 623460
              16  com.adobe.Acrobat.framework   0x004829c4 AcroSecurityBailOutImpl + 637108
              17  com.adobe.Acrobat.framework   0x00483227 AcroSecurityBailOutImpl + 639255
              18  com.adobe.Acrobat.framework   0x00486961 AcroSecurityBailOutImpl + 653393
              19  com.adobe.Acrobat.framework   0x00c63298 AcroSecurityBailOutImpl + 8896904
              20  com.adobe.Acrobat.framework   0x00c65a02 AcroSecurityBailOutImpl + 8906994
              21  com.adobe.Acrobat.framework   0x00c65bd6 AcroSecurityBailOutImpl + 8907462
              22  com.adobe.Acrobat.framework   0x00c65cbf AcroSecurityBailOutImpl + 8907695
              23  com.adobe.Acrobat.framework   0x00909b17 AcroSecurityBailOutImpl + 5384711
              24  com.adobe.Acrobat.framework   0x0064e406 AcroSecurityBailOutImpl + 2519798
              25  com.adobe.Acrobat.framework   0x0064e54c AcroSecurityBailOutImpl + 2520124
              26  com.adobe.Acrobat.framework   0x00b97544 AcroSecurityBailOutImpl + 8062004
              27  com.adobe.Acrobat.framework   0x00b97268 AcroSecurityBailOutImpl + 8061272
              28  com.adobe.Acrobat.framework   0x003798d2 RunAcrobat + 3584087
              29  com.apple.CoreFoundation  0x98c63091 -[NSObject performSelector:withObject:] + 65
              30  com.apple.AppKit          0x9583ccb3 -[NSApplication sendAction:to:from:] + 232
              31  com.apple.AppKit          0x95930caf -[NSMenuItem _corePerformAction] + 536
              32  com.apple.AppKit          0x9593092c -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 171
              33  com.apple.AppKit          0x9592ffb5 -[NSMenu _performActionWithHighlightingForItemAtIndex:sendAccessibilityNotification:] + 79
              34  com.apple.AppKit          0x95c08dab -[NSMenu performActionForItemAtIndex:] + 65
              35  com.apple.AppKit          0x95c08dde -[NSMenu _internalPerformActionForItemAtIndex:] + 45
              36  com.apple.AppKit          0x95a76a10 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 172
              37  com.apple.AppKit          0x958a5916 NSSLMMenuEventHandler + 452
              38  com.apple.HIToolbox       0x97399920 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
              39  com.apple.HIToolbox       0x97215803 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
              40  com.apple.HIToolbox       0x97214c80 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 482
              41  com.apple.HIToolbox       0x97229aa9 SendEventToEventTarget + 76
              42  com.apple.HIToolbox       0x97399de4 _ZL18SendHICommandEventmPK9HICommandmmhPKvP20OpaqueEventTargetRefS5_PP14OpaqueEventRef + 482
              43  com.apple.HIToolbox       0x97399e4e SendMenuCommandWithContextAndModifiers + 70
              44  com.apple.HIToolbox       0x97404697 SendMenuItemSelectedEvent + 275
              45  com.apple.HIToolbox       0x972663f9 _ZL19FinishMenuSelectionP13SelectionDataP10MenuResultS2_ + 129
              46  com.apple.HIToolbox       0x973f4eae _ZL17SimulateSelectionhhPP13OpaqueMenuRefPtPm + 1870
              47  com.apple.HIToolbox       0x9725ded0 _HandleMenuSelection2 + 154
              48  com.apple.HIToolbox       0x9725de31 _HandleMenuSelection + 53
              49  com.apple.AppKit          0x957a1356 _NSHandleCarbonMenuEvent + 302
              50  com.apple.AppKit          0x9573162e _DPSNextEvent + 2196
              51  com.apple.AppKit          0x957308ab -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
              52  com.apple.AppKit          0x9572cc22 -[NSApplication run] + 911
              53  com.adobe.Acrobat.framework   0x0001033d RunAcrobat + 6850
              54  com.adobe.Acrobat.framework   0x0000e9b7 RunAcrobat + 316
              55  com.adobe.Acrobat.Pro     0x00001e92 main + 94
              56  com.adobe.Acrobat.Pro     0x00001e16 start + 54
              Thread 1:: Dispatch queue: com.apple.libdispatch-manager
              0   libsystem_kernel.dylib    0x9859d90a kevent + 10
              1   libdispatch.dylib         0x9832bc58 _dispatch_mgr_invoke + 969
              2   libdispatch.dylib         0x9832a6a7 _dispatch_mgr_thread + 53
              Thread 2:
              0   libsystem_kernel.dylib    0x9859c83e __psynch_cvwait + 10
              1   libsystem_c.dylib         0x9b640e21 _pthread_cond_wait + 827
              2   libsystem_c.dylib         0x9b5f142c pthread_cond_wait$UNIX2003 + 71
              3   com.apple.CoreServices.CarbonCore0x90161f36 TSWaitOnCondition + 124
              4   com.apple.CoreServices.CarbonCore0x900d3579 TSWaitOnConditionTimedRelative + 136
              5   com.apple.CoreServices.CarbonCore0x90135755 MPWaitOnQueue + 200
              6   AdobeACE                  0x01f30737 ACEInitialize + 3741
              7   AdobeACE                  0x01f306ad ACEInitialize + 3603
              8   com.apple.CoreServices.CarbonCore0x901366b4 PrivateMPEntryPoint + 68
              9   libsystem_c.dylib         0x9b63ced9 _pthread_start + 335
              10  libsystem_c.dylib         0x9b6406de thread_start + 34
              Thread 3:
              Thread 4:
              Thread 5:
              Thread 6:
              Thread 7:
              Thread 8:
              Thread 9:
              3   AdobeAGM                  0x0207d79c AGMInitialize + 33770
              4   AdobeAGM                  0x0207d6d6 AGMInitialize + 33572
              5   AdobeAGM                  0x0207d231 AGMInitialize + 32383
              6   libsystem_c.dylib         0x9b63ced9 _pthread_start + 335
              7   libsystem_c.dylib         0x9b6406de thread_start + 34
              Thread 10:
              Thread 11:
              Thread 12:
              1   libsystem_c.dylib         0x9b640e78 _pthread_cond_wait + 914
              2   libsystem_c.dylib         0x9b640f7b pthread_cond_timedwait_relative_np + 47
              3   com.apple.CoreServices.CarbonCore0x900d35a3 TSWaitOnConditionTimedRelative + 178
              4   com.apple.CoreServices.CarbonCore0x90135755 MPWaitOnQueue + 200
              5   com.adobe.Acrobat.framework   0x00068b31 RunAcrobat + 369334
              6   com.adobe.Acrobat.framework   0x00068843 RunAcrobat + 368584
              7   com.apple.CoreServices.CarbonCore0x901366b4 PrivateMPEntryPoint + 68
              8   libsystem_c.dylib         0x9b63ced9 _pthread_start + 335
              9   libsystem_c.dylib         0x9b6406de thread_start + 34
              Thread 13:: com.apple.CFSocket.private
              0   libsystem_kernel.dylib    0x9859cb42 __select + 10
              1   com.apple.CoreFoundation  0x98c52195 __CFSocketManager + 1557
              2   libsystem_c.dylib         0x9b63ced9 _pthread_start + 335
              3   libsystem_c.dylib         0x9b6406de thread_start + 34
              Thread 14:
              1   com.adobe.Acrobat.framework   0x0131462a AcroSecurityBailOutImpl + 15914266
              2   com.adobe.Acrobat.framework   0x0126948f AcroSecurityBailOutImpl + 15213439
              3   libsystem_c.dylib         0x9b63ced9 _pthread_start + 335
              4   libsystem_c.dylib         0x9b6406de thread_start + 34
              Thread 15:
              2   libsystem_c.dylib         0x9b5e882a pthread_cond_wait + 48
              3   com.adobe.amt.services    0x10b9af2c C_AMTUISwitchSuppressUpdates + 16864
              4   com.adobe.amt.services    0x10b93e78 C_EULA_SetState + 2166
              5   com.adobe.amt.services    0x10b9af92 C_AMTUISwitchSuppressUpdates + 16966
              Thread 16:
              0   libsystem_kernel.dylib    0x9859ac22 mach_msg_trap + 10
              1   libsystem_kernel.dylib    0x9859a1f6 mach_msg + 70
              2   com.apple.CoreFoundation  0x98bfb0ea __CFRunLoopServiceMachPort + 170
              3   com.apple.CoreFoundation  0x98c04214 __CFRunLoopRun + 1428
              4   com.apple.CoreFoundation  0x98c038ec CFRunLoopRunSpecific + 332
              5   com.apple.CoreFoundation  0x98c03798 CFRunLoopRunInMode + 120
              6   com.adobe.AcrobatPlugin.EFS   0x0d95698d AcroPluginMain + 22458
              7   com.apple.Foundation      0x95320f7d -[NSThread main] + 45
              8   com.apple.Foundation      0x95320f2d __NSThread__main__ + 1582
              Thread 17:: com.apple.NSURLConnectionLoader
              6   com.apple.Foundation      0x9532d21c +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 378
              Thread 18:
              0   libsystem_kernel.dylib    0x9859d02e __workq_kernreturn + 10
              1   libsystem_c.dylib         0x9b63eccf _pthread_wqthread + 773
              2   libsystem_c.dylib         0x9b6406fe start_wqthread + 30
              Thread 19:
              Thread 20:
              Thread 21:
              0   libsystem_kernel.dylib    0x9859ac5e semaphore_wait_trap + 10
              1   com.adobe.Acrobat.framework   0x0044b18c AcroSecurityBailOutImpl + 409724
              Thread 22:
              Thread 23:
              Thread 24:
              Thread 25:
              Thread 26:
              Thread 0 crashed with X86 Thread State (32-bit):
                eax: 0x00000001  ebx: 0x13ebe7fc  ecx: 0x00000000  edx: 0x00000000
                edi: 0xad115a10  esi: 0x0000000f  ebp: 0xbfffc5c8  esp: 0xbfffc590
                 ss: 0x00000023  efl: 0x00010282  eip: 0x13ebe830   cs: 0x0000001b
                 ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                cr2: 0x03ac9000
              Logical CPU: 2
              Binary Images:
              0x1000 - 0x1fff +com.adobe.Acrobat.Pro (10.1.1 - 10.1.1) <61906DC1-C159-80E3-9766-24C695ABC5D7> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
              0x6000 -  0x1ca6fff +com.adobe.Acrobat.framework (10.1.1 - 10.1.1) <E9429303-C3CA-30F8-2B76-9A36F5018CCE> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
              0x1f2e000 -  0x204ffff +AdobeACE (??? - ???) <42337EF5-3ED6-C0E7-5EB0-2354755A95FD> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
              0x2072000 -  0x2637feb +AdobeAGM (??? - ???) <2C3603CA-70D1-BBF4-57C2-E40222ABDC3B> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
              0x26ea000 -  0x2707ff7 +AdobeBIB (??? - ???) <2FE90606-2817-28E6-3D64-533895E6400F> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
              0x270e000 -  0x2a32fe3 +com.adobe.CoolType (AdobeCoolType 5.08.109.1 - 5.08.109.1) <9BE5826D-CE25-57C1-48CA-4A6B01B1B566> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
              0x471f000 -  0x4720ff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
              0x475c000 -  0x4764fff +com.adobe.asneu.framework (asneu version 1.7.0.1 - 1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
              0x7900000 -  0x7af7feb +com.adobe.Acrobat.adm (10.1.1 - 10.1.1) <20A86BC9-9324-39EA-2521-6CBBD0B6318C> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/SPPlugins/AdobeADM.bundle/Contents/MacOS/AdobeADM
              0x7b9e000 -  0x7ba0ffa +Adobe Unit Types (a2.0.0 - 2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
              0x7ba4000 -  0x7ba8ff7 +com.stclairsoft.DefaultFolderX.osax (4.4.7 - 4.4.7) <1ED423F5-DD3B-549C-E515-F16DE269F6F9> /Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
              0x7d00000 -  0x7f09ffb +com.adobe.AcrobatPlugin.EScript (10.1.1 - 10.1.1) <4C5C428C-344B-280E-3DC6-ADF8A7C70116> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/EScript.acroplugin/Contents/MacOS/EScript
              0x7f79000 -  0x7f7bfff  libCoreFSCache.dylib (??? - ???) <4D047C6F-11FF-3893-A352-5C1E259C036E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
              0x7f8a000 -  0x7f8affb +cl_kernels (??? - ???) <D19AEDD7-94A2-4FCD-B3AC-9F1D4207BD3C> cl_kernels
              0x7f8f000 -  0x7f90ffb +cl_kernels (??? - ???) <9D546B5F-80D5-4A16-98FF-C3C140FA2AFA> cl_kernels
              0xb43d000 -  0xb460ff7 +com.stclairsoft.DefaultFolderX.CarbonPatcher (4.4.7 - 4.4.7) <C5EF29AD-4BE8-8BD6-F08E-82BC3DA3CB80> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
              0xb475000 -  0xb498fff +com.stclairsoft.DefaultFolderX.CocoaPatcher (4.4.7 - 4.4.7) <AD8EC742-6273-4E30-5AD5-63A66481C20A> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
              0xb50e000 -  0xb516ffb  com.apple.URLMount.AFPPlugin (4.0 - 4.0) <DEDDD986-AE2C-3E27-9C6F-5FFD5E6C8D1E> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
              0xc4e4000 -  0xc543fe7 +AcroSQLite (??? - ???) <42034B4C-AB68-4350-8745-C322DD7EDD64> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
              0xc57b000 -  0xc5c4ff7  com.apple.AppleShareClientCore (2.5 - 2.5) <C4D7E3F4-84B6-3F4B-B60D-837C49208323> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
              0xc5d7000 -  0xc5e0fff  com.apple.AppleSRP (1.0 - 1) <334CDC8D-4364-3616-BA06-E8A4ECFFD3CD> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
              0xc5e7000 -  0xc5ecfe2  libcldcpuengine.dylib (1.50.61 - compatibility 1.0.0) <C9714E84-87B3-3EF4-A598-758522D1DB25> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
              0xcca2000 -  0xcd43ff7  unorm8_bgra.dylib (1.50.61 - compatibility 1.0.0) <6C750910-BE8C-3D26-8272-9C4285153DAF> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
              0xcd5c000 -  0xcd5dff8 +cl_kernels (??? - ???) <AC9E7F8E-2712-4815-931B-B67B543E22AC> cl_kernels
              0xcd87000 -  0xcd88ff8 +cl_kernels (??? - ???) <BF5D8F81-6E8D-4018-B04E-5B220105D18A> cl_kernels
              0xd93d000 -  0xd968fe3 +com.adobe.AcrobatPlugin.EFS (10.1.1 - 10.1.1) <85A10F5C-790F-B9C7-3DF3-2A83A080B4F9> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/EFS.acroplugin/Contents/MacOS/EFS
              0xd9c5000 -  0xd9edfff +AdobeAXE8SharedExpat (??? - ???) <6DE8E2CA-91EC-77D7-E674-D336B7D09AF5> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
              0xda02000 -  0xda6cfff +com.adobe.AcrobatPlugin.Spelling (10.1.1 - 10.1.1) <242A0B81-0B01-9DAD-ED35-1A7985DB2CB1> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/Spelling.acroplugin/Contents/MacOS/Spelling
              0xda76000 -  0xdb56feb +com.adobe.linguistic.LinguisticManager (5.1.0 - 13503) <4DC2F672-8C89-29C0-656B-7CF218FDFCD1> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
              0xdb98000 -  0xdbbeffb +AdobeBIBUtils (??? - ???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
              0xde4f000 -  0xde86fef +com.adobe.AcrobatPlugin.Updater (10.1.1 - 10.1.1) <A7BE8957-8462-CF59-7716-8D07A3F4A590> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/Updater.acroplugin/Contents/MacOS/Updater
              0xf001000 -  0xf038ff7 +com.adobe.AcrobatPlugin.PaperCapture (10.1.1 - 10.1.1) <EAC156E5-75FD-977C-D81D-699A9D1F6980> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/PaperCapture.acroplugin/Contents/MacOS/PaperCapture
              0xf104000 -  0xf2d9fe3 +com.adobe.AcrobatPlugin.DigSig (10.1.1 - 10.1.1) <51272EA3-80D5-4562-5841-422AED23D7FA> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/DigSig.acroplugin/Contents/MacOS/DigSig
              0xf399000 -  0xf409feb +com.adobe.adobe_caps (adobe_caps 3.5.4.0 - 3.5.4.0) <36D53A2C-0DAB-34C6-48C7-49D2ECF52D0D> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
              0xf52a000 -  0xf61bfef +libicuuc.40.0.dylib (40.0.0 - compatibility 40.0.0) <B8EDE3B3-7400-E2FC-BA7E-4E5935A54831> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
              0xf741000 -  0xf7beff7 +com.irislink.iDRS14_5 (14.5 - 14.5.4.1) <A30459C2-B559-CF82-60DC-19FE9758BECB> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/PaperCapture.acroplugin/Contents/Frameworks/OCRLibrary.framewor k/Versions/A/Frameworks/iDRS14_5.framework/Versions/A/iDRS14_5
              0xfa00000 -  0xfa5dfff +AdobeXMP (??? - ???) <E3A59E8C-A514-8A4A-F965-E9C043C7AC96> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
              0xfa66000 -  0xfb0eff3 +com.adobe.AcrobatPlugin.PDDom (10.1.1 - 10.1.1) <CF151E29-26BD-E8A9-5A0B-0807D50C1AAF> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/PDDom.acroplugin/Contents/MacOS/PDDom
              0xfb1f000 -  0xfbefffb +AdobeAXSLE (??? - ???) <92D41959-52C9-95C9-BC08-010AAD00A48E> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
              0xff48000 -  0xffe2ff3 +com.adobe.AcrobatPlugin.Checkers (10.1.1 - 10.1.1) <18BDA20B-8EAA-5942-2F68-DF5D630B83D0> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/Checkers.acroplugin/Contents/MacOS/Checkers
              0x10044000 - 0x100d2fef +com.adobe.Preflight (Preflight version 10.1.0 [088] - 10.1.0 [088]) <A1B2B12B-4C50-D360-9372-C63AE4CA6978> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/Preflight.acroplugin/Preflight
              0x1019d000 - 0x1082bfe3 +com.adobe.AcrobatPlugin.Comments (10.1.1 - 10.1.1) <84189F33-8195-2D9A-CE6E-FAF7D855E652> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/Comments.acroplugin/Contents/MacOS/Comments
              0x10a00000 - 0x10a6dffb +com.adobe.amtlib (amtlib 3.5.0.34 - 3.5.0.34) <8C1EBC9E-DDFF-660B-03FB-196CE8A4CED8> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/amtlib.framework/amtlib
              0x10a84000 - 0x10b31ff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
              0x10b76000 - 0x10bddfe7 +com.adobe.amt.services (AMTServices 3.5.0.34 [BuildVersion: 3.5; BuildDate: Tue Sep 14 2010 21:49:00] - 3.5.0.34) <F56D7855-B0F7-4E7E-1997-D4FC2F5ACB2D> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
              0x11537000 - 0x1204bfe3 +com.adobe.AcrobatPlugin.PPKLite (10.1.1 - 10.1.1) <24798AF1-106D-BFA7-7F0A-A5C13A1587C5> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/PPKLite.acroplugin/Contents/MacOS/PPKLite
              0x12100000 - 0x12f13fe3 +com.adobe.AcrobatPlugin.AcroForm (10.1.1 - 10.1.1) <29D02EA8-3F8C-3B2B-CB9D-84CB917E8C49> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/AcroForm.acroplugin/Contents/MacOS/AcroForm
              0x14b30000 - 0x15875ff7 +libicudata.40.0.dylib (40.0.0 - compatibility 40.0.0) <23160F63-D804-A6F2-0363-464FB95A9FF9> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
              0x164fc000 - 0x16a17fe3 +com.adobe.AcrobatPlugin.MakeAccessible (10.1.1 - 10.1.1) <74BDAB11-4513-269C-6989-501B1A860C6F> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/MakeAccessible.acroplugin/Contents/MacOS/MakeAccessible
              0x17000000 - 0x1735bff7 +com.irislink.mac.DRS_iDRS (14.0 - 1127) <CE17CFCF-9CEF-3E67-D455-5F89B5F4BB47> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/PaperCapture.acroplugin/Contents/Frameworks/OCRLibrary.framewor k/Versions/A/Frameworks/iDRS14_5.framework/Resources/DRS_iDRS.framework/DRS_iDRS
              0x1ab11000 - 0x1d1c9fff +com.adobe.PreflightLib (PreflightLib version 10.1.0 [088] - 10.1.0 [088]) <86931B60-FA80-ECF9-6DEA-FB508C361F5F> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Built-in/Preflight.acroplugin/Frameworks/PreflightLib.framework/Prefligh tLib
              0x8fe0e000 - 0x8fe409c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
              0x90005000 - 0x90006ff7  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
              0x90007000 - 0x90094ff7  com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
              0x90095000 - 0x90397fff  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
              0x903c2000 - 0x903cfffe  com.apple.KerberosHelper (3.0 - 1.0) <6612744E-E407-38F3-BBB6-C9C52159B465> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
              0x9042a000 - 0x9058bffb  com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
              0x9058c000 - 0x907fffff  com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
              0x90800000 - 0x90887fff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
              0x90888000 - 0x908b6ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
              0x908b7000 - 0x90a6bff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
              0x90a6c000 - 0x90ae4ff2  com.apple.CorePDF (3.0 - 3.0) <A0EC8F60-A622-347E-979A-F71939C45E5F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
              0x90b0d000 - 0x90b0dfff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
              0x90b0e000 - 0x90b4affd  libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
              0x90d25000 - 0x911c3ff7  com.apple.RawCamera.bundle (3.9.0 - 584) <5CC4C59B-5ECF-9767-2BB1-493AB505F433> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
              0x911c4000 - 0x91225ffb  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
              0x91226000 - 0x91227ffd  libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
              0x91228000 - 0x9122bff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
              0x9122c000 - 0x912fbfff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
              0x912fc000 - 0x912fdff7  libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
              0x912fe000 - 0x91360ffb  com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
              0x91361000 - 0x9137bfff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
              0x91392000 - 0x913aeff5  com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
              0x913af000 - 0x913baffb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
              0x913bb000 - 0x913ceffc  com.apple.FileSync.framework (6.0 - 432) <708CCF30-B544-3681-84A7-8D86BD2CD72F> /System/Library/PrivateFrameworks/FileSync.framework/Versions/A/FileSync
              0x913cf000 - 0x913d5ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
              0x91718000 - 0x9173dff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
              0x91844000 - 0x91851fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
              0x91852000 - 0x91873fff  com.apple.framework.internetaccounts (1.1 - 2) <943A5FFD-265A-39C2-AABF-713A47AB9943> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
              0x91874000 - 0x91c2effb  com.apple.SceneKit (2.1 - 125.1) <7BFC0028-18AC-3B49-8DDC-CB7A7359D4F7> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
              0x91c2f000 - 0x91c42ffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
              0x91d43000 - 0x923eceeb  com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
              0x923ed000 - 0x923f0ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
              0x923f1000 - 0x923f9ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
              0x923fa000 - 0x923ffffb  com.apple.phonenumbers (1.0 - 47) <84484814-C9BE-33E7-A3DF-4DD0E970B902> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
              0x92400000 - 0x92428ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
              0x924a6000 - 0x924abffd  libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
              0x924ac000 - 0x92ec0fff  com.apple.WebCore (7534.51 - 7534.51.22) <A5672ECE-DE06-3FBF-84CE-8AAD5458FDD5> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
              0x92ec1000 - 0x92ec8ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
              0x92ec9000 - 0x92ef6ff7  com.apple.securityinterface (5.0 - 55004) <93C0285A-A266-3F21-82C9-434CBD3FA712> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
              0x92ef7000 - 0x92f6cfff  com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
              0x92f6d000 - 0x92fcaffb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
              0x92fcb000 - 0x933befeb  com.apple.VideoToolbox (1.0 - 705.42) <3F12F8A3-ED41-3EAD-A887-B7805353122C> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
              0x933c5000 - 0x933d0fff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
              0x93a77000 - 0x93ad3ff3  com.apple.Symbolication (1.2 - 83.1) <E651A2F1-CC13-3DDD-9B0A-09180014966B> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
              0x93ad4000 - 0x93ad4fff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
              0x93aff000 - 0x93b0aff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
              0x93b0b000 - 0x93c5dfff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
              0x93d4f000 - 0x93d4ffff  com.apple.quartzframework (1.5 - 1.5) <EF66BF08-620E-3D11-87D4-35D0B0CD1F6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
              0x93d50000 - 0x93d60fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
              0x93d6c000 - 0x93d75fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
              0x940f5000 - 0x9410efff  com.apple.frameworks.preferencepanes (15.0 - 15.0) <7D458EB4-57CE-305E-99D7-2F06403F8097> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
              0x9410f000 - 0x94126ff8  com.apple.CoreMediaAuthoring (2.0 - 889) <49B55753-BD7E-3889-BA60-15294DA49CB7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
              0x94127000 - 0x94180ffb  com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
              0x94181000 - 0x94185ffd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
              0x94186000 - 0x94246ff3  com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
              0x94247000 - 0x94337ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
              0x94338000 - 0x94343ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
              0x94344000 - 0x943d1fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
              0x943d2000 - 0x94410fff  com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
              0x94417000 - 0x9443eff3  com.apple.framework.Apple80211 (7.1.1 - 711.1) <E1813F93-544B-3C5F-9833-9F65E69D31E7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
              0x9451a000 - 0x94595ffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
              0x94596000 - 0x945d6ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
              0x945d7000 - 0x945f9ffe  com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
              0x945fa000 - 0x945feff7  com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
              0x946d0000 - 0x94706fff  com.apple.DebugSymbols (2.1 - 85) <0F996A4A-16A7-3C90-8037-0E2958D1FB16> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
              0x94707000 - 0x9470afff  com.apple.AppleSystemInfo (1.0 - 1) <D2F60873-ECB1-30A8-A02E-E772F969116E> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
              0x9470b000 - 0x94719fff  com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
              0x9471a000 - 0x94740ffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <9C8F1F3D-D570-3F5C-9B31-5B5B82161CDE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
              0x947c4000 - 0x94884fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
              0x94885000 - 0x94901ffd  com.apple.PDFKit (2.6.1 - 2.6.1) <7BC3186B-80B7-3E68-AFDD-2734164BCCFB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
              0x94902000 - 0x94903fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
              0x94983000 - 0x9498dff0  com.apple.DirectoryService.Framework (10.7 - 146) <EDAEA2B3-2BDE-377D-9170-750DE5753029> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
              0x9498e000 - 0x94997ff3  com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
              0x94998000 - 0x949fffff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
              0x94a00000 - 0x94a43ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
              0x94a5c000 - 0x94a7eff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
              0x94a87000 - 0x94b7fff7  libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
              0x94b80000 - 0x9505cff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
              0x952c1000 - 0x955cbff3  com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
              0x955d0000 - 0x955effff  com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
              0x955f0000 - 0x956d3ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
              0x956d4000 - 0x95725ff3  com.apple.CoreMediaIO (210.0 - 3180) <79AA7CA8-FC39-375D-9485-855D302DF7AA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
              0x95726000 - 0x95726ffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
              0x95727000 - 0x961b5ffe  com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
              0x961df000 - 0x96220ff7  com.apple.CoreMedia (1.0 - 705.42) <B45070F1-4097-3BAD-AA7C-0F7AFD6EAC27> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
              0x96221000 - 0x96332ff7  libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
              0x97084000 - 0x970e8fff  com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
              0x97135000 - 0x9720ba5b  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
              0x9720c000 - 0x9720cfff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
              0x9720d000 - 0x9754dffb  com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
              0x9754e000 - 0x9759eff4  libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
              0x97783000 - 0x97892ffb  com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
              0x97893000 - 0x978a1fff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
              0x978a2000 - 0x9797fff7  com.apple.backup.framework (1.3.1 - 1.3.1) <01EF61F8-67B3-33CE-9828-80BE67988A6F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
              0x97995000 - 0x97996ff5  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
              0x97998000 - 0x9799fff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
              0x979a3000 - 0x97a08ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
              0x97a1d000 - 0x97a1fff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
              0x97a20000 - 0x97a25ff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
              0x97ad6000 - 0x97ad9ff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
              0x97b1c000 - 0x97b86ff3  com.apple.CoreSymbolication (2.1 - 66) <B11C9057-1611-36A5-81F6-2C97A7047321> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
              0x97b87000 - 0x97b8fff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
              0x97b90000 - 0x97b90ff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
              0x97ba9000 - 0x97e2efe3  com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
              0x97e5c000 - 0x97eacfff  libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
              0x97ead000 - 0x97ed6ffe  com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
              0x97f23000 - 0x981d2ff7  com.apple.AddressBook.framework (6.1 - 1062) <8992D5C7-DC3C-3009-8A9E-A6937B91BB4D> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
              0x981d3000 - 0x98224ff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
              0x98225000 - 0x982bcff3  com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
              0x982bd000 - 0x982c1fff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
              0x982c2000 - 0x98312ff9  com.apple.QuickLookFramework (3.1 - 500.1) <28CB604E-2426-3491-BF16-2CDFD4C392B0> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
              0x98313000 - 0x98328fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
              0x98329000 - 0x98337fff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
              0x98338000 - 0x983ccff7  com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
              0x983cd000 - 0x983cdfff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
              0x98515000 - 0x98544ff7  libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
              0x98545000 - 0x98546fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
              0x98547000 - 0x98583fff  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
              0x98584000 - 0x985a2ff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
              0x985a3000 - 0x988cdffb  com.apple.FinderKit (1.0.1 - 1.0.1) <48A043DB-B9DB-3D29-B2B6-F19FCA0A1A3E> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
              0x988ce000 - 0x98917ff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
              0x98a8a000 - 0x98a9bfff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
              0x98a9c000 - 0x98bc8ff9  com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
              0x98bc9000 - 0x98d9ffe3  com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
              0x98da0000 - 0x98e08ff3  com.apple.ISSupport (1.9.8 - 56) <963339C2-020F-337E-AFB9-176090F818EC> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
              0x9949b000 - 0x994abff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
              0x994ac000 - 0x99536ffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
              0x99537000 - 0x9961ffff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
              0x9962c000 - 0x9962dff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
              0x9962e000 - 0x996ebff3  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <ADBA42F5-0130-315B-880C-70AA70666474> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
              0x996ec000 - 0x996ecfff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
              0x996ed000 - 0x9972bfff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
              0x99756000 - 0x99bcbff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
              0x99bcc000 - 0x99c07fff  com.apple.bom (11.0 - 183) <39257FE6-8B23-39B6-9528-57184104A98F> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
              0x99c08000 - 0x9a283fe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
              0x9a2c1000 - 0x9a2f5ff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
              0x9a351000 - 0x9a361fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
              0x9a36a000 - 0x9a36eff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
              0x9a36f000 - 0x9a771ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
              0x9a774000 - 0x9a774fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
              0x9a775000 - 0x9a779ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
              0x9a77a000 - 0x9a77dffd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
              0x9a8ab000 - 0x9aa0dfff  com.apple.QTKit (7.7.1 - 2306) <5A7E5ED0-C4DC-3CEC-ABE0-24899134ACE1> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
              0x9aa0e000 - 0x9aa1cff7  com.apple.AppleFSCompression (37 - 1.0) <5D91F412-7B04-335D-8E1A-AFD463859EA2> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
              0x9aa23000 - 0x9aaf9ff6  com.apple.QuickLookUIFramework (3.1 - 500.1) <4E259D94-6081-32D7-AD60-565E57B11EBA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
              0x9aafa000 - 0x9ab48ff3  com.apple.ImageCaptureCore (3.0.1 - 3.0.1) <DB40F137-4519-339B-81DC-7375B2FE8FD2> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
              0x9ab49000 - 0x9ab4bffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
              0x9ab4c000 - 0x9ab60ff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
              0x9ab61000 - 0x9ac38ffb  com.apple.avfoundation (2.0 - 180.30) <6788562E-A9A8-3898-A0F4-66D9BBAE3430> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
              0x9ae3a000 - 0x9aedefff  com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
              0x9aedf000 - 0x9afeeff7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
              0x9b02e000 - 0x9b02fffd  com.apple.MonitorPanelFramework (1.4.0 - 1.4.0) <45AC1CB9-2A81-3FEA-9BA4-E9BBA2582A28> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
              0x9b030000 - 0x9b24fff7  com.apple.imageKit (2.1.1 - 1.0) <9AF0A882-BEAD-3AEC-8A72-497A7C3C2358> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
              0x9b250000 - 0x9b258fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
              0x9b259000 - 0x9b2bbff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
              0x9b2bc000 - 0x9b2d2ffe  libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
              0x9b2d3000 - 0x9b301fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
              0x9b31c000 - 0x9b564fff  com.apple.JavaScriptCore (7534.51 - 7534.51.21) <FEDF4D88-FB61-3A3F-ABE2-72BE2234DDF4> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
              0x9b5e0000 - 0x9b6abfff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
              0x9b6ac000 - 0x9b6b4ff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
              0x9b6b5000 - 0x9b70dfff  com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
              0x9b718000 - 0x9b72dff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
              0x9b72e000 - 0x9b72efff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
              0x9b72f000 - 0x9b752fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
              0x9b753000 - 0x9b797ff3  com.apple.framework.CoreWLAN (2.1.1 - 211.3) <48490EAB-CFD4-33A5-86E6-DE9CA59296A8> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
              0x9b7ca000 - 0x9b7cefff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
              0x9b7cf000 - 0x9b7d8ffb  com.apple.DisplayServicesFW (2.5.2 - 317) <DF4FCE9C-A4EE-3590-B079-495AC83836EA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
              0x9b7d9000 - 0x9b848fff  com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
              0x9b8a7000 - 0x9b8a7ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
              0x9b8a8000 - 0x9b8b3ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
              0x9b8b4000 - 0x9b94fff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
              0x9b950000 - 0x9ba70fec  com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
              0x9ba71000 - 0x9ba74ffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
              0x9ba9b000 - 0x9bad1ff4  com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
              0x9bad2000 - 0x9bb08ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
              0x9bb09000 - 0x9bb0cff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <B9344DE6-B84D-352C-95AD-EF73A68B8A10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
              0x9bb32000 - 0x9bb4bfff  libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
              0x9bb4c000 - 0x9bc63fe9  com.apple.WebKit (7534.51 - 7534.51.22) <00C929E8-969F-3933-9801-6A12AFF5D461> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
              0x9bc6f000 - 0x9bc99ff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
              0x9bdad000 - 0x9c05fff7  com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
              0x9c060000 - 0x9c07dfff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
              0x9c07e000 - 0x9c0cdffb  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <71C9D388-E607-3DB4-9FD3-FC918EB4A835> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
              0x9c0ce000 - 0x9c0d0ff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
              0x9c0d1000 - 0x9c0dbff2  com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
              0x9c0dc000 - 0x9c0e2ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
              0x9c0e3000 - 0x9c0eaffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
              0x9c0eb000 - 0x9c0ecfff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
              0x9c145000 - 0x9c18cfff  com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
              0x9c18d000 - 0x9c1d7ff2  com.apple.Suggestions (1.0 - 85.0) <F623AF82-5CF4-3F68-909B-2B3C5820FE3B> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
              0x9c1d8000 - 0x9c51afff  com.apple.MediaToolbox (1.0 - 705.42) <5AEFD5BE-6FA3-38F8-966A-B0AB56C472B8> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
              0x9c51b000 - 0x9c704ff7  com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
              0x9c705000 - 0x9c730fff  com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
              0x9c769000 - 0x9c791ff0  com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
              0x9c792000 - 0x9c7afff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
              0x9c7b0000 - 0x9c9d9ffb  com.apple.QuartzComposer (5.0 - 236) <7BD138F0-C748-3013-98C0-4D5F5E10B9AB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
              0x9ca0d000 - 0x9ca0efff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
              0xbb100000 - 0xbb103fff  libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <E04F79A8-130A-3529-8D8A-E62821CF6A81> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
              External Modification Summary:
                Calls made by other processes targeting this process:
              task_for_pid: 391
              thread_create: 0
              thread_set_state: 0
                Calls made by this process:
              task_for_pid: 0
              thread_create: 0
              thread_set_state: 0
                Calls made by all processes on this machine:
              task_for_pid: 21455
              thread_create: 6
              thread_set_state: 0
              VM Region Summary:
              ReadOnly portion of Libraries: Total=356.3M resident=243.6M(68%) swapped_out_or_unallocated=112.7M(32%)
              Writable regions: Total=272.6M written=85.4M(31%) resident=165.3M(61%) swapped_out=0K(0%) unallocated=107.3M(39%)
              REGION TYPE                  VIRTUAL
              ATS (font support)             32.1M
              CG backing stores              11.2M
              CG image                        656K
              CG raster data                  192K
              CG shared images               3480K
              CoreGraphics                      8K
              CoreServices                   3880K
              MALLOC                        184.9M
              MALLOC guard page                32K
              MALLOC_LARGE (reserved)         276K    reserved VM address space (unallocated)
              Memory tag=240                    4K
              Memory tag=242                   12K
              OpenCL                           44K
              SQLite page cache               192K
              Stack                          77.3M
              VM_ALLOCATE                    17.2M
              __CI_BITMAP                      80K
              __DATA                         25.8M
              __DATA/__OBJC                   220K
              __IMAGE                        1256K
              __IMPORT                         64K
              __LINKEDIT                     66.0M
              __OBJC                         3216K
              __OBJC/__DATA                    44K
              __PAGEZERO                        4K
              __RC_CAMERAS                    236K
              __TEXT                        290.3M
              __UNICODE                       544K
              mapped file                   108.6M
              shared memory                  15.3M
              shared pmap                    6092K
              TOTAL                         848.8M
              TOTAL, minus reserved VM space848.5M
              Model: iMac11,3, BootROM IM112.0057.B00, 4 processors, Intel Core i7, 2.93 GHz, 16 GB, SMC 1.59f2
              Graphics: ATI Radeon HD 5750, ATI Radeon HD 5750, PCIe, 1024 MB
              Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x01BA, 0x202020202020202020202020202020202020
              Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x857F, 0x483634353155363446393333334700000000
              Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1067 MHz, 0x01BA, 0x202020202020202020202020202020202020
              Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1067 MHz, 0x857F, 0x483634353155363446393333334700000000
              AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.58.4-P2P
              Bluetooth: Version 4.0.1f4, 2 service, 18 devices, 1 incoming serial ports
              Network Service: Built-in Ethernet, Ethernet, en0
              Network Service: AirPort, AirPort, en1
              Serial ATA Device: ST31000528AS, 1 TB
              Serial ATA Device: OPTIARC DVD RW AD-5680H
              USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
              USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa140000 / 5
              USB Device: SoundSticks, 0x05fc  (Harman International), 0x7849, 0xfa141000 / 8
              USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa142000 / 6
              USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
              USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7
              USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa120000 / 3
              USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
              USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0xfd140000 / 5
              USB Device: ScanSnap S1500, 0x04c5  (Fujitsu Ltd.), 0x11a2, 0xfd141000 / 6
              USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 4
              USB Device: Built-in iSight, apple_vendor_id, 0x8502, 0xfd110000 / 3
              FireWire Device: unknown_device, OWC Mercury Elite-AL Pro, 800mbit_speed
              FireWire Device: OEM ATA Device 00, NewerTech Voyager Q, 800mbit_speed
              • 4. Re: Adobe X OCR Crashes in Lion
                Thanks for sharing this carsh log. This would be helpful while debugging this issue.
                Could you please share the file also wherein you saw this crash. Please mail the file to apangasa@adobe.com
                • 5. Re: Adobe X OCR Crashes in Lion
                  jayKapp Level 1
                  Will do
                  Jay
                  • 6. Re: Adobe X OCR Crashes in Lion
                    jayKapp Level 1
                    I believe I cracked this problem on my computer.  This problem occured after I scanned in a document using my Fujitsu Scan Snap S1500M.  I occured after upgrade to Adobe Acrobat X.   I think this is a workflow issue.
                    I was scanning in a document then going stright to the OCR tool.  Adobe crashed after the OCR process.  I noticed that at the bottom of the scanned message right after I scanned it, was a small box with the words: "Task 1 of 1 Recognize Text (using OCR).  At times a save dialog would come up.  I was cancelling the save and going straight to the OCR task.  ;
                    Ths time I waited for the save dialog and saved the scanned file to the location I wanted using the file name I wanted.    Once it was saved I ran the OCR and there was no crash.  This test used an 8 page scanned document.
                    This workflow change seems to do it for me.
                    Jay
                    • 7. Re: Adobe X OCR Crashes in Lion
                      failed_spirit
                      I am also seeing reproducible crashes in Acrobet 9.4.6 in OS 10.7.2 when trying to use a ClearScan OCR format.
                      The searchable image OCR format does work without crashing, so that's a workaround until this gets patched.
                      Do you want to see my crash report?
